New guy needing help
Started by rsbhunter, July 09, 2012, 05:38:23 PM
rsbhunter
I am new to the site, and glad i found it! I saw a reply by AMB30518 about using an aluminum guide for the Granberg Mini Mill....I just tried my new mini mill and noticed that my beams looked warped, end to end......Checked my guide 2x6 that WAS straight when new, and it was the exact shape as my beams!!!! The beams were just to try out the mill, so no big loss...Where can i get an aluminum guide, and what configuration do you use? I see 2"x6"x 12' rectangle alum tubing, but between the $123.00 for the tube, and another probably $80-100 for shipping (12' long) it is a bit steep....BUT, if it works, it will over time , be a good investment......Iv'e also thought of a 2"x6" composite board used for decks? Any ideas? Thanks, rsbhunter
"If you stand for nothing.....Then you'll fall for anything"
POSTON WIDEHEAD
Rsbhunter....I am unable to answer your questions but I can take time out to WELCOME you to the forum.
They'll be a little get together tonight with punch and grits in your honor as a new member, at 8:00pm at the wood shed.  :D
You'll have a good time on the FF and will sure learn a lot.
Again, Welcome.
David
Delawhere Jack
Hunter, Welcome.
So the rails of your mill have some twist in them? Try getting three good straight edges (hardwood, hardwood plywood whatever) that you can lay across the rails, one at each end, and one in the middle. Of course they all need to be the same height. Then sight across the top of them and level your rails until they all line up.
(If a Granberg is not a bandmill, then disregard my reply.... ;D)
Sprucegum
Sounds like your 2x6 plank warped when you wern't looking  :(
I made a guide out of steel angle iron 1/8 x 1 1/2 x 1 1/2 because I didn't plan on carrying it very far but found it was quite light  8)
I used it on every cut because it made pushing the saw much easier. I even waxed it with car wax  :)
Welcome to the Forum.
Get another 2x6 and keep checking it for "straight". Some will stay straight, and others will not. But suspect it is the cheapest route to take in the interim.
Nomad
     Some people use an aluminum ladder.  I guess it would work pretty good.  I've got the guide from Granberg.  Not the cheapest thing in the world, but light, strong and easy to use.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
boatman
For the mini mill i just take the aluminum v track and attach it on a 2x along a chalk line.   Your first cut will trim the edge of the plank.
Then just check it before use each time and reattach the v rail if needed.
losttheplot
I glued a couple of scrap pieces of 3/4ply together attached the guide rail to a chalk line then trimmed the edge of the ply with the first cut same as boat man.
http://youtu.be/PL7eTJjZWs0
DON'T BELIEVE EVERYTHING YOU THINK !
schakey
Welcom rsbhunter ;)
Did someone mention GRITS?!!!! digin_2 smiley_blue_bounce
Think-Dream-Plan-Do
PC-Urban-Sawyer
rsbhunter,
Pay no attention to David. He's just trying to get your goat. You shore don't want to go anywhere near the Woodshed here.
Sounds like you're getting pretty good advise on your guide problem.
Just remember: Be Careful!
Herb
rsbhunter
Thanks for all the welcomes.....(even the woodshed) reminds me of a joke about a "Montana Wingding" , but's thats another time....i might go the plywood doubled route, but reallywanted a 12'. Guess i could splice ....On the angle iron guide, are you using that with a Minimill? If so, how did you attach the guide rail sections? The only hold up on the aluminum rectangle tubing is i don't know if i would tack weld the guide bars, or have to drill and tap the tubing to take machine screws???? But please keep the replies going, as i love the ingenuity that goes into each style....Thanks again, hunter
Welcome to the Forestry Forum, rsbhunter.   :)
rsbhunter,welcome to the forum. What are you sawing and building? By the way,GRITS are Girls Raised In The South,grits are the ones I don't like.
Ray,
Like I said before, it is a start  :D.
rsbhunter
I'm building a small house/cabin . I plan on using the beams and boards (if i get into sawing boards) for sills, and beams for a small 8x12 shed.....nothing major, just hate to let the trees go to only firewood...rsbhunter
Good luck and have fun sawing.
Piston
Quote from: Sprucegum on July 09, 2012, 06:12:38 PM
Sprucegum, that's a great idea!
rsbhunter, welcome to the forum  ;D
-Matt
rsbhunter
I have been thinking of different ways to achive a non-warping "board"...even considered making a square 1-1/2" tube ladder type frame (alum) and spot welding the guide rails to it.....Plywood souds do-able, even considered 3/4" plywood with a 1" sq alum tube mounted flush to the edge on each side  almost like a "U" channel..... I really believe in the do it right the first time, but it didn't work with the first 2"x6" board i got!!!!!!!!!! I'm in a small town, limited places to buy materials....Thanks for all the welcomes.....makes one glad to be a member....hunter
Sprucegum
THe plywood with aluminum trim sounds good. If you want 12-foot boards make your guide 14 feet. Its nice to be able to drive off the end of the log without loosing the straight line cut.
losttheplot
perhaps try  a 2x6 box beam out of plywood, screws and glue ?
Or a torsion box beam made of ply.
Are you attaching blocks of wood,  each end of the log, to support the guide?
fat olde elf
You need to get and read the Malloff book "Chainsaw Lumbermaking" I've been told that it is out of print, but you can find used copies. I've milled thousands of feet of oak and pine with a 5 inch Husky 381 and a granberg mill prior to buying my Cooks mill. It is hard work but it can be done. Say your prayers...
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
rsbhunter
Think for my next attempt, it will be 3/4 plywood, glued and screwed together......should i use an epoxy type glue for waterproofness? Thanks for all the advice, alot of "plan B's " are available now.....hunter
Ga Mtn Man
I would just use a water-proof woodworking glue like TiteBond III.  Much less mess than epoxy. :)
