PEEEE-YOOOOOOOOOOOOOO
Started by Fla._Deadheader, March 05, 2004, 04:44:19 PM
Fla._Deadheader
We sawed this butt-ugly log tother day, and, MAN-O-MAN does it stink !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  ::) :o
  It DID have some interesting grain, though. It was also, HARD !!!
  Take a look.  BTW, it STILL stinks ::) ::) ::)
Frickman
That's some interesting looking spalting going on there. How much of it is rotten, and what kind of wood is it?
sawwood
 Wow nice looking spalting and grain. How long has it been
 setting ? Is the Cypress Fla ?
 Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Fla._Deadheader
  There's absolutely no rot. The piece is hard through and through. Don'T know how long it was sitting.
  We have 1---2" thick board and about 5---1" boards.
  Remember the "Chicken S***" Tree" post a short while back??? This MIGHT be that. It could be Chinaberry??? It could be something else???  I posted a "What is this" title in Plant ID last week, and got little response. I did post a pic of the bark???
  It actually smells like 15 Horses have been peeing on the log for 40 years ::) ::)
Frickman
No Rot huh? That hunk of wood sure'd make a purty bench in the front hallway.
Fla._Deadheader
That's what my son was thinkin of making. Problem is, when he gets a weird piece, he puts a high price on it, and someone shells out the bucks, and the piece is gone???
  He is wanting to build a Grandfather Clock, using Chocolate Cypress, or Midnight Cypress. It is a very dark color, like Choc., or Midnight??? ;D ;D
Brian_Bailey
Looks like veneer to me  :D :D :D
WMLT40HDG35, Nyle L-150 DH Kiln, now all I need is some logs and someone to do the work :)
crosscut
think you have you a spalted holley tree there not sure if the smell is from bacteria or just plain rotten wood i run into quite a few smellly trees.here in fl. specially if they are in serious decline or newly dead for a lack of better description lol
shopteacher
FDH,
    You didn't cut that near one of them transient northern rest homes, did ya?  You know them old men don't see to well anymore. You might have cut down their urinal.
woodbeard
Looks a lot like hackberry, but I've never known hackberry to be very hard.
Fla._Deadheader
Crosscut, where ya been??? ;D
  You MIGHT be correct. I fergot about that Holly stuff. :o ;D ;D
Flurida_BlackCreek
Looks like spalted wormy hickory to me.
I'm happy anywhere south of the mason-dixon line.
-- cdb
redpowerd
dredged from outhouse basement?
nice wood, looks wormy to me.
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
dail_h
   If it's hard,it probably ain't chinaberry. Pretty though
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
RMay
looks like persimmon to me  :)
RMay in Okolona Arkansas  Sawing since 2001 with a 2012 Wood-Miser LT40HDSD35-RA  with Command Control and Accuset .
LeeB
I'm stil thinking hackberry or mayhaps elm. Really pretty stuff. LeeB
C_Miller
Harold,
on a totally unrelated note. Did you ever get the immovable log out of the swamp?  I was thinking that it might be the one that's covering the drain so you may not want to disturb it after all.
C
CJM
etat
Me too, how about an update FLA.   Didn't let that piece of log get ya down did ya :) :) :)
crosscut
hey ya fl we have been busy cuttin trees here. just cut down a huge sycamore. first limb we cut i knew tree was bad to the bone. got over half tree down.and tree was looking better and better old rotten rancid smell kept getting worse though finnally 3inches from the ground we found a huge cavity 3 inches from the ground 8 inch rotten spot appeared on it and underneaneath that was nothing but rotten and and worse even a bore test wouldnt have shown up on this tree. took the homeowner out and showed him sure made him feel better as i know he hated to lose the tree
Fla._Deadheader
Steve, ya doin any sawmillin???  We still gotta get together and let me pull the stick on yer circle mill. These guys postin all them pics of their circle mills gets me itchin to do 1 more round ;D ;D
  Guess that Sycamore wasn't sawmill quality, huh ::) ::)  I'd like to get a decent Sycamore and Q-saw it on the Bandmill. Q-sawn sells well, here ;D ;) ;) :D
  No go on the "monument" log, YET. We been so busy with "land" logs, we haven't even BEEN on the water.  Gotta pressure clean the bottom of the barge. Anybody know if a 3000# pressure cleaner will have any pressure underwater ???
Probably enough pressure under water that you will have to tie Ed's .....er...  tie Ed to something or you might have to chase him down the river :D
swampy
No Tom, thats why we keep it in shallow water, ;D the pressure will force me to the bottom and pin me fast so I can't go anywhere. :o :o ;D
It only takes a little sawdust to become addicted. It's even better when you build your own. (HOMEMIZER a.k.a. HOMEY)
Well, if you are going to point that thing up, make sure you know where your Daddy is standig and squirt him every once in a while for me.  I'll laugh. :D
Fla._Deadheader
