sawing tulip popular
Started by Gary_B, June 30, 2012, 09:43:30 AM
Gary_B
I just cut down a nice tulip popular, before I saw the log, should I let it dry some first, or saw it in a large cant and let it dry some before I mill it into 5/4 lumber. I know popular can really twist and bow. Years ago I bought some green popular lumber and it seem to have a mind of its own as it was drying out. I know its better to nail it up green fresh off the mill, but Id like to use some of the lumber for interior trim..
OneWithWood
I would mill it as soon as possible.  How large is the tree?  Smaller diameters may bow and crook more than larger trees.
One With Wood
slider
A while back i sawed some green .stacked and stickered it right away.The mostly i by stuff 8 to 12 in wide.Some of the top boards moved around some but the rest did well.good luck.al
al glenn
No waiting.  I would saw and sticker it.
T Welsh
Gary_B, Bust it down and sticker it right away! Poplar is a well behaved type of wood, where you will see twist and shout is when you get sapwood mixed in. I use butt logs and try to get most of the outer sap wood off the cant. Tim
YellowHammer
I like to saw poplar sap dripping green, the saw will cut it like butter.  Seal the ends, sticker it well, put another stack of stickered lumber on top of it for weight and it should stay straight.  In this heat, it'll dry real fast.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
tyb525
I cut about 1500 bf of tulip poplar a couple summers ago, 4/4 all widths narrow to wide. I'd say 90% of it dried great. The ones that didn't were close to the pith.
Don't believe the myths you hear about letting logs "season" before you cut them. That only causes problems 99% percent of the time. Saw it up into the thicknesses you want ASAP. The only exception is if you want boards thinner than 3/4, in that case they are hard to dry that thin, so cut thicker boards and resaw them when dry.
Gary_B
Thanks for all the replies, tomorrow morning the mill will be running, really anxious , havent sawed anything nice and straight for a long time, Id say the base was around 28 inches. I cut the tree into 10 ft lengths. Looks like I should get nice stack of lumber out of the logs.
Quote from: tyb525 on June 30, 2012, 03:33:24 PM
Ty,
I have to disagree with you on this one.  It actually causes problems more than 99.5% of the time  :D.
Ron Wenrich
Letting tulip poplar logs lay will cause your sapwood to stain.  Putting it on wet stickers will give you sticker stain.  Not having enough air flow in your bundles may also cause sapwood to stain.  It won't plane out.
