greasing turntable on knuckle boom
Started by slider, June 22, 2012, 12:14:06 PM
slider
Anyone have any experience with a US crane knuckle boom.I can't find a grease fitting anywhere on the turn table.The pinion gear has a removable cover for adding grease.I have been packing grease in there.So far the big gear seems to be well greased but is it getting to the main bearing.I think they are out of business ,can't find them on google search.I can take pix if it will help.thanks al
al glenn
tlandrum
give it a good cleaning and you may find where the zerk fittings are broken off
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
slider
Did already looked everywhere just not there .I will go over it again thanks.When greasing the pinion gear and rotating it i get grease coming out from all around the turntable may be it's getting to the center bearing.
al glenn
customsawyer
I think you need to put that new skid steer on that truck and bring them up here and I will help you look. ;D
www.thecustomsawyer.com
