What is it?
Started by Lud, June 13, 2012, 08:58:00 AM
Lud
I won't make you wait too long
Sprucegum
Its a boot & pistol remover for one of them Tall Texans  ???
Weekend_Sawyer
It's one of them puzzle boxes.
You couldn't get it back together so you just nailed it back together! :D
Imagine, Me a Tree Farmer.
metalspinner
I'd call that a blind Bambi, cause I have no-eye deer.
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
Texas Ranger
Lathe attachment of some kind.  Additional support?
The way Lud is having birthdays, he will be on social security before we find out.   :D
jamesamd
All that is gold does not glitter,not all those that wander are lost.....
purple otter
Hudson Oscar 228 on homebuilt trailer, Kubota B2320 with homebuilt forks,Stihl 028 Super & 029 Super, Solar Kiln .
It's something you put together to make us think it's something.  :D  I'm a blind bambi too.  ;D
sandhills
Wooden abstract art, I like it!!   ;D
Lud
The puzzle I was faced with was getting a consistent angle for stool leg mortises from an old Milwaukee drill I use with the big bits.  The jig has two "2-stage" dogs that turn up and down to let the hole be "3 inches up and an inch and a half  in" on the base of the stool.  I drill opposite corners,  turn down the dogs,  and do the other two corners.   Switch to a new blank and do the same corners,  turn down the dogs and do the original orientation corners.
I'd use a bigger base piece if I were to do it again for better clamping options but it works pretty good....better than just eyeballin' it.
I also drilled through another piece of scrap wood with the bit.  Cut thru the diameter of the hole on the band saw and shaped a handle for a gauge.  When I turn the leg ends into tenons , the gauge gets me real close to the hole size tho I always drytest.  Then I saw the end and make a contrast color wedge.  Titebond III and a hammer give a nice tight joint.
That is finding a solution with some thoughful Ohio Engineering.   smiley_thumbsup
terrifictimbersllc
Still think it's a 50x wooden pattern for the clutch pedal position switch on my F-350.  ;D
POSTON WIDEHEAD
Quote from: terrifictimbersllc on June 16, 2012, 08:16:33 PM
:D :D :D :D :D
