replaced piston and cylinder on 440 stihl
Started by Bolie, May 23, 2012, 12:05:37 AM
Bolie
any particular breaking in tips? this is a first for me and it cranked. any info will be greatly appreciated!!!!
Bo
If you want to do something bad enough you'll find a way,If you don't you'll find an excuse!!!!!!!!
Al_Smith
Set the carb just slightly rich for a couple of tanks .The saw will tell when it's ready by the increased compression .Then lean it out til it's right and run it like you stole it . ;)
CTYank
It's generally considered good practice for the first 10 hours or so to:
add a little oil to the mix (40:1 vice 50:1, say)
avoid long full-power runs (give it fast-idle breaks)
give it a short warm-up before full-power, and a cool-down before switching off
richen high-speed mix a bit beyond optimum (see below)
at all times: use good-quality fuel & oil; clean chips & dust from cover & fins. Shake mix well before pouring.
Optimum H carb adj.: engine 2-strokes under load in cut, just 4-strokes when lifted (load reduced)
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
nmurph
Clam77
Andy
Stihl 009, 028, 038, 041, MS362
Mac 1-40, 3-25
