A little red oak.
Started by customsawyer, May 22, 2012, 07:57:48 PM
customsawyer
Here is a little red oak for you guys. It is 42" on the big end and a hair over 30" dia. on the little end.
I won't begin to tell you how long it took to saw this thing.  These biguns are a little difficult to turn.
www.thecustomsawyer.com
moandrich
How long is that? It looks like a monster.
woodmizer lt 40HD  2007
Kubota RTVX1100 2019
Kubota L3940   2009
LOGDOG
What did you mill it into? That is a beast ....
Whoa!!  That is incredible.  My hat is off to you, Sir, Sawyer of Huge Logs.
5quarter
That log has gotta be 6 tons. Paul Bunyan might have to pull up a stump and think how turn that one. :D
Blue Harbor Refinishing
customsawyer
It is actually a little less than 5 tons. I cut 4/4 grade off the sides to make a 12X12X40'. It wasn't as bad as some I have done but it did take a little better than a hour to cut.
How long are the longest side boards and do you trim them to a specific length?
Jemclimber
That must be quite a job just getting it to the mill.  It must take some Heavy equipment.
lt15
Norm
clww
Great piece of a tree you have there! Great work 8)
I look forward to seeing pictures of a 12X12X40' beam, too.
Many Stihl Saws-16"-60"
18-Wheeler Driver
terrifictimbersllc
I was edging 20 ft boards today.  Hate to think of edging the ones from that log.
scsmith42
Tom's 3638D Baker band mill
JVK
Do you have the chain turner on the 24' ext as well? If you do, will both turners roll that log or do you have to tractor assist sometimes?
Lud
If you gotta big log, you gotta have "John Wayne sized equipment" ! 8)
Jake knows "John Wayne sized equipment" . ;D
250quality
I've got a bush full of logs just like that. No market here for them so most go to firewood.
customsawyer
This one was a little bigger but still made me tired.
I had a bunch of big boards come off of this one that was as pretty a board as you have seen.
250quality you are making me cry thinking about burning these logs.
JVK I have the claw type turner on the ext. plus the other hyd. that would come on a LT40 except the loader. You will need every thing that you have to work with to turn these biguns.
WDH I measure the boards as I am cutting so that the man running the boards to the edger can cut them to different lengths before go to the edger. Depending on the best lumber from the log but on a 40' log I try to get 2 16' boards and one 8' board. If the length is different then go for other boards.
If you go to my website you can watch a little video of me cutting a 36' log. Watch for the hand signals that I give to the man on the edger so that he can just feed the edger and not have to take the time to measure anything. This helps him get the boards out of my way so I can bring him another.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
customsawyer
I will have to get a pic of a sweet gum for MM.
customsawyer
If it is a really big one, it might cause nightmares  :).
Perish the thought.  But just think, If you had them all, I would be free of them forever.
John S
Just checked out your video.  Great job with the LT70 and great music from Merle!
2018 LT40HDG38 Wide
customsawyer
Just for the record I don't always drink my beer in a tavern. I have been known to open one or two at the house. :D
Danny I did a big sweet gum once and got 4 12X12X 40' out of it if you remember. I don't think MM liked that one any more than the rest of them.
customsawyer
I think that I will have to go have a beer after seeing that  :D.  Nightmares for MM for sure  ;D.
