keep blades clean
Started by locdogg, May 21, 2012, 10:41:01 AM
locdogg
still new to milling but discovered this yesterday.
keep the blades clean as you can!
been milling mostly ash and red oak.
i have an ez boardwalk model 40 and the top of the blade stays pretty clean (from lube dripping on it).
however if i bent over and looked up, i could see pitch/wood crud/whatever building up on the bottom side of the blade. (just on the teeth, sorry i should i have took a picture)
i sprayed some simple green on the underside and held a wire brush to it and wow.  the blade cuts like brand new again.
anyway thought i'd post in case other newbies hadn't discovered this.
Chuck White
Ash is notorious for leaving deposits at the base of the teeth on a bandsawmill.
When I saw Ash, the water is running a good steady stream and I rarely get any build-up!
mikeb1079
i too had a problem with pitch buildup when first sawing ash.  thanks to this forum i tried a mix of water/cascade liquid soap and i got my mill back to cutting straight.  yes it's critical to keep your bands clean.   :)
homebuilt 16hp mill
kelLOGg
