blade life
Started by ssgerken, March 17, 2012, 07:38:30 PM
ssgerken
Hey everyone,
I know there are many variables that come into play here, but how many board feet of 2x4's can you expect to get out of one blade before you need to re-sharpen?
thanks,
Steve
Kansas
There are too many variables in that question. Are you out in western Nebraska where the pine forests crop up? Hardwood? What kind of hardwoods, are they yard trees, green or old dried out logs? In green hardwoods, preferably not oak, maybe 600-1000 ft. Red oak you might get that. White, I doubt it. And then its also a local issue. We don't get all that much out of a blade for cottonwood. Too much silica in the log, or at least we think it is. But then we pull fairly quickly on blades and resharpen ourselves.
It really does not matter what dimension lumber I am sawing.  I make about the same number of passes through the logs in a given time.  If a blade is still running at lunchtime, I generally go ahead and change it out.  Two blades per day is good for me and blade sharpening cost does not enter into my blade changing decision.  If they are suspect, they get pulled.
Chuck White
Today, I sawed right at 2,000 board feet of Hemlock.
2x4, 2x6 & 2x8, mostly 4's & 6's and only 16 8's and used 2 blades.
The last blade was still cutting good when I pulled it at the end of the day.
First one was actually changed early because the debarker was out of adjustment.
POSTON WIDEHEAD
Quote from: Magicman on March 17, 2012, 08:39:03 PM
MM, how many blades do you generally take to a job?
Thanks. D
Majic is as close as your going to get,two bands a day unless you hit tramp or gritty logs. Frank C.
cypresskayaksllc
I assume the question is about bandsaw blades. How long does a circ saw last before resharp?
LT40HDDR, JD950FEL, Weimaraner
ssgerken
So getting 300 board feet cutting dirty old creosote power poles is pretty good?
Quote from: ssgerken on March 17, 2012, 10:31:10 PM
No.  I do not saw dirty creosote power poles, period.
Aside from the dirt, you have the creosote which softens as the blade passes through which then collects on the blade.  It then will tend to cause the blade to dive, etc.
Others will have issues about the chemicals, but I just do not saw it, so that doesn't affect me.
I think that that (miss you Tom) is pretty good!
Quote from: POSTONLT40HD on March 17, 2012, 08:56:47 PM
My Magic Saw Can holds 8 blades and has never been emptied.  I carry an extra box of 10 when traveling, but have yet to use any of them.
Magicman's Saw Can is a cut down garbage can.
POSTON WIDEHEAD
Quote from: Magicman on March 17, 2012, 10:47:02 PM
Well shut my mouth......GOOD IDEA!
ladylake
 I used 9 resharpened blades in the last 2 days sawing 5400 bf white oak 90% 1" , most not too big.    Steve
cypresskayaksllc
nothin is good with dirty old creosote poles
red oaks lumber
thursday i sawed 6100bf of creasote soaked railroad tressel d.fir used 5 blades. ( you can call me dumb) i do :D
Adventurous, maybe  ;D.
No, I do not.  Never bet against another man's tricks or talents.   Sometimes you just gotta scratch where you itch.
I just ain't gonna itch for creosote.  Period.
red oaks lumber
no danny if you saw the stuff i am willing to do in the name of satisfing the customer ,you would call me dumb. i do :D :D
I still do not, no matter what the reason.
5quarter
ssgerken...Where in NE are you? I'm in Springfield, about 25mi SW of Omaha.
Blue Harbor Refinishing
ssgerken
5quarter... I'm about 8 miles south of York. 50 miles west of Lincoln.
Cypress,you asked about a circular saw.I think most sawyers file twice a day,but cut much more in the time frame than the bandito. Frank C.
