saw head lift motor
Started by cluckerplucker, February 16, 2004, 05:25:34 PM
cluckerplucker
12 vdc motor for saw head using a atv winch motor,piece of pipe as shim and chain sproket
cut in half.
cecil
rbarshaw
Looks good.  ;DDoes it work well? What's the rest of your mill look like?  :P
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
cluckerplucker
It works great beats the heck out of the socket and wratch that I was using.
cecil
rbarshaw
Man, I know I have a hand crank on mine that will wear you out :o. Nice looking mill 8), wish I'd made mine a 4 poster.
redpowerd
Looks like it would pull itself outa the mud in a  pinch!
how big is it?
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
Good looking rig, CP. You design and build it?
Fla._Deadheader
  CP, keep that up, and before ya know it, you will have a fully automatic mill 8) 8)  Nice job ;) ;D
cluckerplucker
the motor is rated for 2000 lbs cost 50.00 from harbor freight.com, item# 90282-1RAH. Yes I designed and built the mill But with a lot of input from others.David was helpfull in where I could obtain the acme rods and nuts.Ihad about given up trying to find them long enough.Orginally I was going to build a two post But once I started I figured a nother 20 feet of tubing would be worth the time and money.  Thanks  cecil
cecil
