How many bands have you broke?
Started by hackberry jake, March 02, 2012, 03:11:49 PM
hackberry jake
I just broke my third band today. I'm sure some of you have lost count.
Dave VH
I broke the first band that was in my saw when i brought it home.  In the first 4 inches of log.  Had about a 6 inch piece fly better that 40ft away.
  so far that was the only one that i've broken (knock on wood)
I cut it twice and it's still too short
Dewey
Bibbyman
Probably a couple hundred .... a year.
Sawing since '94
hackberry jake
Man bibby, that's a lot of sawing!
medic
#1.  First cut into a log, hit a thin piece of metal at just the right angle and sheared the band in two.
#2.  Tried to back out of a cut once.
#3.   Had a brand new blade break as soon as the teeth touched the edge of the log.  [However, seeing how high my 16 y/o could jump when part of the blade snaked off the mill made this one worth while  :) ]
scott
Retired Paramedic, TimberKing 1400, Logrite cant hooks, old MacCullough chain saws.  Too many projects not enough hours in the day.
cypresskayaksllc
2. Both broke after I wore a flat spot on my guide wheel. A piece of debris got wedged between the wheel and a bar thats by the wheel.
LT40HDDR, JD950FEL, Weimaraner
hershey
When I was running the Mizer LT-70 we broke alot that was the mode of failure.My homebuilt bandmill I've never broke even one, they get sharpened many times and get to 1 1/4 from 1 1/2 and loose the tooth hardness,and start to wonder.Probibly less tension leads to their long life. Frank C.
tcsmpsi
Probably 20 or so.  Multitude of reasons.  Haven't broken any of the newest blades I've started using, and have pushed some of the long and hard, where I figured they would break just any moment.  Never had a piece of blade leave the covers, though.
\\\"In the end, it is a moral question as to whether man applies what he has learned or not.\\\" - C. Jung
hershey stole my answer.   ;D   Every band will break because of the rearward stress and traveling around the bandwheels.  I had one to break in two places last week.  After I got it out I noticed another crack.  I just smiled because I know that I had gotten every bit of the "goody" out of it.
In all, I had 3 to break on last week's job, but to be fair about it, they were from a box of blades that had been pushed back and were not in my normal rotation.  They were from my original batch of 60 blades that I bought over 10 years ago.   :)
Virtually every box of 10 that I send back to ReSharp includes at least one broken band.
Sawmill Man
   25 years of custom sawing adds up to a lot broken bands. A customer was looking at a pile of broken bands one day and said he would change brands if he were me. I explained that he was looking at every brand that there was and that they all eventually break from metal fatigue unless they damaged by metal in their logs.
"I could have sworn I went over that one with the metal detector".
T Welsh
After 5 or 6 sharpenings they all will let go at some point. thats what I buy them for to get the maximum out of them,had one that lasted 9 resharenings a couple of weeks ago,thought to myself,this is on tough blade,then it let go about 5 cuts later.after you run enough,you will see a pattern develop and can almost know when its going to break. by the way I only use Woodmizer blades. Tim
cutterboy
Quote from: medic on March 02, 2012, 03:40:17 PM
scott
:D :D :D :D :D :D  I jumped pretty high the first time a blade broke on my mill. :D :D
To underestimate old men and old machines is the folly of youth. Frank C.
Al_Smith
I really have no idea if it's true or not so I'll just throw it out here .They claim a rubber tired bandmill as most homebuilts are is less apt to break  blades .True fact or old wives tale ,have no idea  ???
pineywoods
Enough to make it worthwhile to haul them to the scrap yard  ;D
POSTON WIDEHEAD
Quote from: Al_Smith on March 02, 2012, 07:15:25 PM
Old wives tale.  :D :D :D
terrifictimbersllc
Quote from: POSTONLT40HD on March 02, 2012, 08:28:39 PM
Old wives tail.  :D :D :D
Tale.   this is the Forestry Forum.  >:(          :D
Al,theirs some truth to it as rubber tired bandmills run larger diameter bandwheels,and homemade mills usally don't tighten the bands as much. Frank C.
POSTON WIDEHEAD
Quote from: terrifictimbersllc on March 02, 2012, 08:41:40 PM
Sorry, didn't mean to do that. I never cud spell. I changed it.  :)
Bandmill Bandit
There is an article in this month's Sawmill & Woodlot about blades.  Just click on the "Download PDF" below the article "Why Blade Saw Blades Break".  https://www.sawmillmag.com/app/home/index
I found it while doing a cruise through the Sponsor's Websites.   :)
never finished
 Quite a few. But I'll never forget the first one. It sent me and my two sons running. It even took me a while to build up the nerve to go shut off the mill. No one told me that might happen. Yep that was before I found this place.
kelLOGg
I went through a rash of breakage 3 - 9 months ago. I think it was due to too much down pressure on the moveable guide (11/16") . Since I reset it back to 5/16" I have not broken one. I haven't counted the ones I have broken.
Bob
Chuck White
Since I started sawing I would have to say I have had 5 boxes of 15 blades each to break, totaling 75 blades.
I have to admit though, there were times I would hear the ssstt, ssstt, ssstt, and I'd stop the blade and find a crack and pull the blade, so that one wasn't really a break.
