progress pictures on my bandmill build
Started by bruce29, February 16, 2012, 09:32:04 PM
bruce29
Thought I would post a couple pictures of my progress . I dissasembled my mill after completion to paint it. I am currently in the process of reassembling it .
Berggie
Home built/modified Linn 1900, Dolmar saw, farmall H with loader. Log rite.
Cutting Edge
I am impressed too  :o  Easy to tell you have an eye for the details!  And obviously very talented.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Ga Mtn Man
Bill Gaiche
For what I have seen so far, ita a really great build. Good luck with the rest of the mill. bg
jueston
steamsawyer
Man, Bruce, that is beautifull. It really looks professional. 8)
Countless hours of hard work.
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
Migal
Stihl learning and picked up my Log Master LM2 Cat 34hp 02 21 12! 230MF+ the toys that go with it! MS361 MS271 Stihl PB500 Echo 48" LogRite 16ft Bass Tracker Pro' Abua Garcia 5600 bait caster, Wood working equipment' Lake Lot never enough time! oh don't forget the fridge with ale! Loving Wife Rebeca
redbeard
Nice work! heavy duty log turner and red looks really nice on your mill. good job Bruce
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
pyrocasto
Nice looking mill for sure!
How do you add the "teeth" to the chain for a log turner anyway? I never could figure out an easy way.
sandhills
SWEET, what else can I say.  Very nice job.  Also very nice shop, someday I WILL have one with a hoist also  :).
hackberry jake
I wanna know what all of the ten hydraulic levers do!
customsawyer
That is a very nice looking mill. You are very talented.
www.thecustomsawyer.com
bruce29
A job well done,now an automatic band sharpener and two sided setter, should be a piece of cake. Frank C.
bruce29
sorry about the typing layout on the 10 control explanation . should of reviewed before posting
Ga Mtn Man
Quote from: bruce29 on February 17, 2012, 06:49:56 AM
Well, at least we know there's ONE thing you're not an expert at.  ;D  Can't wait to see VIDEO of the beast in action.
Jemclimber
VERY nice job with lots of thought.  I would love to see what you thought of to keep sawdust off the inverted angle.  Is it just a brush? Do you have pictures?  Ever since the galleries icon link was removed from posting link I can't seem to find a particular person's gallery.
lt15
You have to go into profile and redo the icon. I did mine.
Jemclimber,I have the same rail setup on my bandmill and sawdust is not really a problem.The little sawdust that sticks seems to just form thin patches and flake off. A brush could be mounted ahead of the "V" wheel if it ever became a problem. Frank C.
eastberkshirecustoms
Very nice looking build bruce29! Have any pic's of your head rig, or are you waiting to mount it to the bed first? How about sharing some spec's and capacities. I see you mounted the controls on the 'tail end' - I'd be worried that some dumb @ss would run into those expensive hydraulics in transport. If I'm correct it looks like you have three roller toe boards, 3 loader arms, and 4 squaring arms (2 powered and 2 manual)? I guess you want to cover your bases for short and long stock! Are you using the overhead cable or energy chain to carry your hydraulics along? Again, nice work and keep those photos coming!
bruce29
I have 3 taper rollers --3 powered backstops and 2 manual backstops. The seat assy comes off in transport & the control station pivots in & out of the way. the cable run carrries the power to the cutting head. I hope to finish painting the head & carriage assy and I will post more pictures.
Bruce you'll be a good sawyer,and not afrade to adjust and improve your mill.There are many folks that buy a bandmill and are scared stiff about adjusting anything.You are the world authority on your mill,and from what I can see its world class.You probibly could not afford to build and sell them like that. Frank C.
You just put the WOW back into wow !!!  That is an awesome build.  It also looks like you are in a very well equipped shop.   :)
