Log wall farm stand
Started by FarmerFrye, February 09, 2012, 11:33:15 PM
FarmerFrye
Hi, Thanks for the great information you all provide on this site.
I am farmer in Massachusetts considering buying a band saw primarily to build structures in the fashion of log homes. I like the rustic look of log homes and the idea that you can build a structural wall that is also insulated appeals to me. It seems like it should be less labor intensive than stud framing.
    My plan is to cut the trees, primarily pine, in the spring, mill them into 8"x8" cants and in late summer/fall lay one on top of the other horizontally to make my walls. I will need some bracing and the first cant will lay on a pressure treated sill so as not to rot and the roof over hang would be such that rain does not hit the cants.
  I know it is not as simple as this but am I crazy to think this would work and why don't more folks build this way? I can think of a few problems and I hope you will tell me they are not such big problems as to make the idea a bad one.
    Will I be able to mill cants straight enough so that they lie perfectly on each other with no gap between cants? I want to eliminate air infiltration so as to keep structure well insulated.
    If I cut, mill and set to dry in the spring, will the wood be too wet to build with in the fall? If I build with wet wood and cants are still drying in place will they likely warp and create big gaps between each cant?
     Is there a potential for moisture in cants to cause rot or mold where one sits on the other?
Thanks so much for your responses
dukndog
FarmerFrye,
Welcome to the Forestry Forum!!
As for the "log home" I'm not too experienced with it. I do know with the band mills out there, cants are pretty much square. It's all in the storage treatment or making sure they are stacked well while waiting on the building process.
Lots of knowledgeable people here to help you though, and one of the best is in the upper east part of Mass., Mr. Jim Rogers!!
Welcome again!!
DnD
WM LT-15G25 w/PwrFeed, Mahindra 3510, Husky 385xp, Stihl MS261 and a wife who supports my hobby!!
jander3
Welcome,
You could stack and stake the logs into a wall.  In general, I don't care for that construction.
1/2 Dovetail log construction, is easy to learn and reasonably quick.   These buildings are designed such that you need to chink the gap.
Here is a link that shows you how to layout a 1/2 dovetail:
http://peelinglogs.blogspot.com/2011/06/12-dovetail-layout.html
1/2 dovetail sauna plan:
http://peelinglogs.blogspot.com/2011/06/12-dovetail-sauna-design.html
Timber framing or Piece en Piece construction are other building options that use timbers or logs.
tyb525
Farmer Frye, good question. Regardless of whether you use your method, or Jander3's, you will need to chink the gaps. If you lay cants on top of each other like you describe, you just won't be able to keep the straight enough to prevent gaps. So rather than trying to keep gaps closed, I would put chinking in between them.
Chinking is mud and grass/fiber, or oakum. Basically a mortar to fill the gaps.
http://en.wikipedia.org/wiki/Log_cabin
Welcome to the Forestry Forum FarmerFrye.   :)
dave_dj1
If you mill the logs yourself, take the time to use a router and put a 3/8" groove in the center of each log so you can install a spline, maybe even two with some foam snake in between. It will help stop the air and water and make it over all a better product.
