Kiln thermostat
Started by jmcq, February 04, 2012, 07:19:21 PM
jmcq
Hi all,
I am in the process of building a kiln and need a thermostat to control the circulation pump on the wood furnace.
I need one that goes up to at least 160 degrees.
I am using a wood furnace that heats water to 180 degrees and then pumps it into a rad in the kiln.
Any suggestions would be appreciated.
Joe
05 WM LT70 D62
allagashwoods
Joe, give Grainger's a call, they have a great tech dept and will find you what you need. I bought a high temp. thermostat from them along with a high temp probe and a couple of other things for my firewood kiln and was very happy with the Co.
                                         Good Luck,
                                                 Len
Ga_Boy
Are you drying fire wood or lumber?
