Spalted Maple slabs PICS included
Started by GAmillworker, January 31, 2012, 04:20:29 PM
GAmillworker
Thought I would share some pics.  More to come
Thank the Lord for second chances
POSTON WIDEHEAD
You never know what it looks like until you saw it in two. This is what gets me up in the morning.  8)
Full Circle
That's some beautiful wood.  Thanks for posting.
-Roy
fullcirclefarmandforest.com
GAmillworker
Letting others make the big money.  I'm just selling slabs.
Lud
Nice looking spalt.  Nothing like a bit of spalt on a bowl to bump up the value.  8)
GAmillworker
Riggs
Every man's life ends the same way. It is only the details of how he lived and how he died that distinguish one man from another.~Ernest Hemingway
Norwood ML 26
GAmillworker
It just does not get any better than that  8).
LOGDOG
Wow! What do you charge for slabs like that if I may ask?
metalspinner
GAmillworker
Okrafarmer
This may have been asked before, but is there a difference between ambrosia and spalting? Is ambrosia a type of spalting? I get a lot of ambrosia maple around here. I'm building up a batch of around 1,000 bf to mill and probably 2/3 of it so far is heavily ambrosia-brewed. Also-- question-- if the logs have spalting or ambrosia in them when the tree is still a live, does it continue to grow "better and better" in there if you leave the logs to sit around a while?
Now selling Logrite tools!
LOGDOG
Quote from: GAmillworker on February 01, 2012, 09:03:09 AM
Quote from: LOGDOG on February 01, 2012, 07:39:21 AM
$75-$150
Wish you were closer. I'd buy a pile of them off you.
tyb525
Ambrosia is a beetle, and yes it is different than spalt. If a tree has spalt while it is still standing, it is most likely not alive anymore. Logs will spalt on the ground, however it's kinda of a crap shoot as to whether it will be good spalting, or just rot.
samandothers
Well, now I know the price.  Since I don't know, I have to ask, how big is a slab?
GAmillworker
Quote from: samandothers on February 01, 2012, 07:25:12 PM
the ones with crotch are 48" long  30" wide @ widest part & 24" at smallest part thickness very from 1-1/4" thick to 3-1/2".   The butt cuts are 48" long 24" wide.
The color associated with the hole in ambrosia maple is caused by a fungus that hitchhikes in on the body of the ambrosia beetle that bored the hole.  It is similar to blue stain fungus.
Spalt only occurs in trees that have died or have been cut, never in living trees.  Like Ty alludes, spalt is a stage of the decomposition process.  It is more dramatic in certain species, and not so much in others.  Sycamore and maple spalt very nicely.
okmulch
I made a lamp out of some spalted maple.
Rotochopper b66 track, #2 Rotochopper b66 track, woodmizer lt40, CAT 277b, CAT 268b, CAT 287c, CAT 277c, CAT299d2, CAT299d3, CAT 299d3, Volvo 70e,volvo70f, volvo90f
samandothers
Thanks for the info.   Very nice slab.
Okrafarmer
I've heard of spalted beech. Does ash spalt? I think I may have seen some recently.
eastberkshirecustoms
I have no experience with spalted wood at all, which brings to mind a question. How solid is it? It does look nice, but it is essentially 'rotted', right? Is it softer or less durable than unspalted? Thanks in advance guys for the edgamacation.
Okrafarmer
And what is the etymology of the word "spalt"? Was it originally just the redneck version of the word "spoiled"?  ???
GAmillworker
Quote from: eastberkshirecustoms on February 01, 2012, 10:07:44 PM
Spalted maple is as solid as any other maple. It is not rotten and soft.  I'm sure someone else can tell us more.
It's the very first stage the wood decaying. A fungus grows though the wood and feeds on the easy to process sugars in the wood, and stains it, without significantly weakening the actual structure of the wood. If you can then cut the log and dry it the fungus stops and you still have solid wood. Leave it a few months more and the fungus starts breaking down the actual cellulose that makes up the wood structure. That's when it goes punky and rotten.
There may be some slight weakening of the wood, but as it's usually used for decorative rather than structural use it's not enough to worry about. Spalting usually occurs in non-durable wood, so if it gets wet in the future the decay can start up again, but as long as it's dry the decay process is stopped.
Other thing to watch is fungus spores in the sawdust when you are working with it. Some people get a nasty allergic reaction to it.
Spalting definitely weakens the wood, but if it is managed in the early stages, the difference is not material (solid as GAmillworker said).  However, there becomes a fine line between spalt and the beginning of rot as Ian says, and the trick is to stop the decomposition process to keep the wood in the spalted stage and not let it enter the doty or punky stage.  It is an art rather than a science.  Some of the best spalt is what Mother Nature does on her own, and you just luck onto it.  It is a matter of time and temperature and humidity, since all wood begins to decompose in the natural environment once dead except for the really rot resistant ones.
GAmillworker,
Do you intentionally spalt wood using a recipe, or do you just dig around and see what Mother Nature did on her own?
Ok, thanks guys! I'm beginning to understand. I ask because I got an itch to build a spalted maple coffee table. Would it be best to have a poured-on epoxy finish to seal up the wood from future decay and any release of spores, or will regular ol' polyurethane suffice?
metalspinner
Any old finish can be used on the table.  Spores that cause spalting are already in the air that we breathe. That's how they ended up on the wood in the first place.
Fine Woodworking had a really nice article recently on the dangers of wood dust.  Their conclusion was that spalted wood dust was as bad for you as any other wood dust. Wood dust is a carcinogen and protection in the form of a dust mask and extraction are the best ways to avoid future complications while working with wood.
Regular Poly will be fine. The fungus is only dormant spores once the wood dries.
Yes the spores are naturally in the air, and can cause problems there already. Toxic mould issues in damp houses for example. It's when start sanding something like that and have 1000X the amount floating around....
Of course you should avoid breathing too much wood dust anyway, but the spalted wood has the extra hazard that you might be allergic to the fungus. It may have no effect on you, or some people might break out in a rash or have breathing problems when exposed to it.
Just be aware it can happen, and if you have a reaction, take extra care.
terrifictimbersllc
Spalted areas on maple soak up much more finish than unspalted areas.  I wouldn't consider using it for a cutting board.
tyb525
I've seen spalting in many species, but certain species look better than others.
I cut some spalted beech once. An odd length log, 4 feet, it was left after cutting a log down to a length I could saw. I let it lay in the feild all summer, and it had some nice spot, mostly just on the side that was on the ground. The top side was just stained.
Spalted Dog
If you find some wood with great spalting you can still stabilize it if it is not too far gone.  I have used 2 part epoxy, Minwax wood hardener, or acryloid B-72, super glue.  I think there is a product through Packard turning catalog that you can stabilize wood with I think Pentacryl?. The acryloid B-72 seems to be the best all around.  I use it mainly in knife handles, pistol grips etc.  The wood pretty much turns to plastic.  This in turn makes the dust absolutely toxic so repirator required.  The finished product is great, and solid.  I will use it on a table when I find a piece good enough.
The older I get the less I used to know.
GAmillworker
Quote from: WDH on February 02, 2012, 07:53:05 AM
It was just
              L  aboring
              U  nder
              C  orrect
              K  nowledge
No really,
It was just laying in someones yard(they said it had been laying there for years).  I asked them if I could get it out of the way for them.  They were glad to have it hauled away.
Nothing wrong with the Laboring Under Current Knowledge Plan  :D.
Tdawg
$75-$150
GAmillworker, don't take this the wrong way because I am completely uninformed, but it just seems to me that these slabs should be worth more...I mean look at them!!! How do you arrive at that price? And who do you sell them to?
GAmillworker
You are right with the right marketing, exposer, & time you can get a lot more.
That being said,
I think I'll pm the boss of FF and see if I can donate one for the auction.
PC-Urban-Sawyer
Spalted Dog,
Could you post a link to your source for the acryloid B-72?
Thanks,
Herb
jueston
Quote from: GAmillworker on February 02, 2012, 09:34:22 PM
That being said,
I'm sure plenty of forumites would be interested in bidding on that, i would.
tyb525
Back before I had my mill, I came a cross an old rotten buckeye log. I shouldn't say it was old, it was only down half a year. It fell in the spring, and buckeye degrades VERY fast once on the ground.
I cut a few turning blanks out of the more solid areas with a chainsaw, and turned a bowl out of one of them. Boy it was nice, I wish I could've milled some lumber from it.
You were certainly correct about it being nice.   Good turning job also.   smiley_thumbsup
tyb525
Thanks MM, one thing I noticed is it soaked up the finish to no end. I put on countless coats of butcher block oil, then walnut oil, and it still looks like it did straight off the lathe :D
Wow Ty, that looks awesome!  I have some hickory that has been down for a couple of years that I plan to put on the mill and "open' up soon.
Spalted Dog
Museum Services Corp in the Twin Cities for the B-72.  It comes in pellet form and is disolved in Acetone.  This stuff is not to be take lightly, especially the sanding after it hardens, respirator required.
You will have to play around with your ratio of pellets to acetone.
cutterboy
Will red maple spalt? I know sugar maple will. I have some red maple trees on the ground that came down in an ice storm two years ago. Is there any way I can tell if thay are spalted by looking at them? Will black birch spalt?
POSTON WIDEHEAD
WOW......all that spalt makes my eyes cross. BEAUTIFUL work TYB.
ellmoe
Quote from: cutterboy on February 26, 2012, 08:36:14 PM
Yes it will, quite nicely.
cutterboy
Thanks ellmoe. I'll have to go check out those downed trees.
customsawyer
Danny if those hickories are very large I am expecting a call. ;D
www.thecustomsawyer.com
caver
I have cut some Tulip Poplar with that spalting. I didn't know it had a name...just thought it looked cool. I may have to cut some slabs out of my last TP on the mill as it has some spalting too.
Baker HD18
Jake,
They are kind of small and rotten  :D.
Okrafarmer
I've noticed recently that sweetgum spalts pretty nicely.
