Help sharpening chain
Started by joejkd, January 17, 2012, 11:00:08 PM
joejkd
Having trouble getting my saw chains sharp. I've tried a freehand file with a guide clipped to the file, and a granberg file jig. Neither seems to get the saw particularly sharp. I checked my rakers and they're ok for now.
The trouble I think I'm having is figuring out the depth on the granberg. There is no guide as to just how low I should set the file. The general rule is 20% above the top plate, but trying to visually check 20% of a 5/32" object is not exactly precise.
Does anyone have a better method for the granberg? Would I be better off with an electric purpose-built grinder? I need the most fool-proof method, as my vision is not so good for finish work.
I use my saw for about 5 hours every weekend.
Wood Doctor
Dear Joejkd, First and formost, never let your chain touch anything but clean wood. You can use a wire brush or hand ax to clean any grit or dirt off your logs and stop short from the ground if your not using a buck. I only hone my teeth with 1 or 2 passes before I start to cut. I do it free hand and always try to follow the guide marks on the chain. If I do get a chip or dull the teeth unwillingly, I have it reground at the Co-op for 5 bucks. Also, carry an extra sharp chain when you go out and it will save you time and effort in the field.The more that you use your saw the more practice and skill you will aquire to keep your teeth sharp and cutting clean.As for the guides; I am sure with practice you will master them as well. ~m~
Joe
I sharpen by hand, and last couple years have used a small guide.
Depth of file is controlled by the rollers and angle by the guide mark on the tooth. The guide also includes the raker guide for hardwood or softwood.  About a $10 item that I get from a Husky dealer and believe it is branded Pferd.
T Welsh
joejkd, here is Stihl,s video of how to care for a chain and sharpen it. it will help and explain all stages of how to sharpen. Tim
http://www.youtube.com/watch?v=qvcCh2XqEPc&list=UU1149B-W0eHs_XWBq_8gBzw&index=4&feature=plcp
It just takes time. I doubt you will get the hang of it in 2-3 chains, But once you understand what you are doing wrong,the rest is easy. Get some cheap glasses from the dollar store too. You need to see what you are doing wrong. Keep at it,you will get it. I have many rocks and hit them too. I can get a chain back getting pretty good. Yes,I destroyed 2-3 chains before I caught on to it.
lumberjack48
joejkd at 6.48 minutes in to the video where hes filing a raker, look at the cutter in front of it, you'll see that shinny edge on the cutters top edge.
You have to file on till that shinny edge is gone, you can watch it disappear every stroke you make, when you don't see it any more the cutter is sharp.
You can file all you want, if that shinny edge isn't gone its still dull, i hope i explained this so you understand it.
The main thing is don't get disappointed, if it doesn't cut good, take a good look at it, and file it again. Theres no reason to pay somebody to sharpen you chain.
If you have a problem, post a picture, we'll tell you what your doing wrong.
fuzzybear
  One thing most people forget to do is to file each cutter to the SAME length. They can be razor sharp and still cut like @#$% if they are not the same length.  If you do not have a micrometer you can use an adjustable wrench to check length.
  Start with your shortest cutter and file it sharp, then set the wrench on it to get the length, then file the rest the same length. Then adjust your rakers to the correct depth.
  If you keep them sharpened correctly the saw will cut like a hot knife through butter with little effort. If they are not the same the saw has to work overtime and so do you.
  Happy filing.
FB
I never met a tree I didn't like!!
John Mc
Personally, I've found having the teeth all the same length to be over-rated. If you use the appropriate tool for setting the height of the depth gauges in relation to each individual tooth (rather than the tool that rests across the tops of two or more teeth), you can compensate for a lot of variation in tooth length. I still make some effort to keep the length somewhat close, but I do that by eyeballing them. I don't get worried about minor differences in length. I hand file, and my chains (round-ground, full-chisel) cut straight and fast - generally as good or better than new out of the box chains.
lumberjack48
I agree a 100% with John Mc, if the length of a cutter isn't noticeable by eye there close enough.
One of the best raker gauge's i found is the Carlton File-O-Plate, it lays over each cutter individual, you can get one from Baileys or Ebay, make sure you get it for the chain your using, full chisel, semi chisel and ect, each chain uses a different numbered file-o- plate.
A new chain out of the box is dull, look at the edge of the cutter, theres a little bit of a shinny edge on it. Thats the first thing i did was put a good edge on it and touch each raker with the flat file. [ just touch ]
T Welsh
Cutter length can be tricky with a bar 24" and over. I am teaching one of our crew leaders the finer points of getting a 36" saw to cut straight,he has a problem understanding equal length, and raker height. thats when I found the video and told him to watch it. he came back the next day and said I understand it now. and he does,but his skills need to be honed, he uses my saw and just smiles,then he get frustrated using his. I told him it will take time and it will come to you. I am making him file his saw and not use the grinder. it will teach him to be accurate. Tim
John Mc
Most of my Oregon chains have been fairly sharp out of the box, but their depth gauges are up too high (higher than the Oregon spec). The other thing I've noticed with their chains lately is that they seem to have way too much hook on the teeth. It certainly makes them grab and cut well when bucking, but it can be a pain in the neck when you're bore cutting... they get too "grabby"
T Welsh
We use our saw,s in all conditions.boring,bucking,felling,ect. you can match your chain to any condition,but for good all around performance I stick pretty close to OEM spec,s. I am careful not to file the rakers to much,its hard on the saw and gets a little dangerous when you take them down to much,it will cut like a b--ch,but dont get complacent with it,or you will end up with a unexpected result. Tim
Al_Smith
Everybody has a favorite method .The trick is finding what works for you .
Some stick the bar ,saw and all in a vice .Some sharpen first the left cutters and then the right .
The method I use is straight over the back of the saw doing alternately the lefts then the rights progressively going over the whole chain .I can see the angles better .
Willard does it with the saw sitting on his lap .Seemed awkward to me but works well for him so that's all that matters .End results count, methods do not only for arguements sake which really isn't worth much .
lumberjack48
In the spring of 66 i was staying in camp with an ole Fin, he was about 50, i was 18. We were cutting an peeling tree length Aspen, up by Ash River, between International Falls and Cook MN. [ 50 cents a tree ]
Setting on a chair he held the saw between his legs with the bar at the 35 degree's, this way he filed straight across, the saw was tilted at the right angle.  ::)
I tried it over an over, it didn't work for me.
John Mc
Quote from: T Welsh on January 19, 2012, 06:46:52 AM
... for good all around performance I stick pretty close to OEM spec,s...
That was partly my point. I'm finding that some of the Oregon chains I'm buying does not meet their specs for depth gauge setting, and for the amount of hook on the tooth. This is new, out of the box chain. It cuts great for bucking-type cuts. However, that long thin point from the excess hook on the tooth doesn't last long, and is a pain for bore cuts.
After a hand sharpening or two - to the angles and depths they specify, it's better: longer lasting, and bore cuts just fine
fuzzybear
Quote from: John Mc on January 18, 2012, 06:22:38 PM
My question is, would you sharpen your table saw blade without regard to cutter size, how about a band blade? If you've invested large money into equipment and you like that new out of the box performance of the chain, Why would you not take the few extra minutes to maintain that performance and protect the investment you have made?
  When you take a chain that has cutter that are unequal and sharpen it and adjust each raker, it will never cut as good as it does out of the box. A saw chain is tuned to cut a certain way.  If you do not maintain that tuning it will never cut as good as new.
  If you sharpen a set of planer blades and set them in at a slightly different height, it would still plane lumber but it would never run correctly or produce the same results as if you took the time to tune the blades.  A chain saw is the same principle.
   Most people will hit an object that will destroy a couple of cutters, they then sharpen those cutters removing a large amount of material to do so. If you do not remove the same amount from the other cutters they will stand at different heights, thus producing a low spot that will not produce the same result as the rest. This is where you get the slight "rattle" as you are cutting.
   If you take the time to retune a chain after hitting an object, you can then go back to the tried and true method of using the same amount of strokes to touch up the cutters.
  Just my $.02 worth.
FB
John Mc
Fuzzybear: A chain saw is not a table saw or a band saw; there are significant differences in what goes on during the cutting with "fixed" teeth such as these, and teeth that have more of a "float" (and in fact make a porpoising motion) as they cut through the wood.
I might agree with your description a whole lot more if I were using the depth gauge tool that so many of the dealers and hardware stores around here are using: it's one that lays across the tops of two or more teeth, so you are setting the depth gauges sort of to an average of those teeth. This is not tuning the depth gauge very well for the tooth it actually affects. Further, as the teeth wear back, the depth gauge needs to have a slightly different height in relation to the tooth. These depth gauge tools have no way to compensate for that. They're better than nothing, but far from ideal.
The depth gauge tools that sit on one tooth, and angle down in front of it, with the end resting on the body of the chain, rather than the tooth are basically customizing the raker for the tooth which follows it. Because of the geometry of how these work, they also help to compensate for the different relationship between the tooth and the depth gauge as the tooth wears back. The old Carlton File-o-plates are one such tool. Here's another (I use the one on the left):
I'm not advocating for totally ignoring tooth length, but with the appropriate depth gauge tool, some degree of difference between tooth length makes no difference in cutting performance.
John Mc
I agree with your approach and good reasons. I too figure if a rocked tooth needs to be shortened, then the worst it can be is that it doesn't contribute to the cutting. But see no need to knock back good teeth just to say they are the same length as the one or two shorter ones.
One reason I only take a chain to someone with a grinder, even one I think knows how to use it. ;)
If I am going to file a circular blade on my table saw, it will first get place on the mandrell backward and all the teeth will be jointed using a stone to the same lengths. Then file each tooth to remove that jointed land ending up with all the teeth the same length and hopefully the same sharpness.
Any carbide teeth are different treatment.
I have a similar depth gauge as yours for individual teeth on my pferd two-roller jig pictured earlier.
Add to this that discussions of skip-tooth chains are made by grinding some of the teeth off shorter. ;)
Al_Smith
If you take the short tooth from a rocked chain and cut the depth gauge down just a little deeper  it's doubtfull you'd be able to detect a short tooth or two by the way it cuts .
Now a race chain you want every thing just so so but on a work chain you can be pretty leniant .
fuzzybear
  like it was said before, you find a way of doing things that works for you and you stick to it. My self I work until dark, about 4pm in the early spring, and that leaves me time to spend cleaning and maintaining equipment. I find that sharpening the saw is peaceful and helps me relax after work.
   I REALLY hate dull tools. My axes,knives,saws must be razor sharp and ready to work. I.ve been accused of over sharpening my knives. Some one always gets cut when they use my knives.  My first duties when I worked with a master sword smith was sharpening, he was very fussy on the correct way of sharpening and could produce a blade that would literaly could cut a human hair dropped on it. I could never produce the edge he could, but then again he had been doing it all his life.
  I have been using carbide impregnated chain for a while now, and I have to say I'm impressed so far. Alot less sharpening, even after cutting through an embedded nail and rock. Took very little effort to get it sharpened and not alot of material lost. And at $.33 a drive link it was worth it.
FB
Al_Smith
I'm confused on that one .Are you saying the carbide chain was 33 cents per driver or it cost 33 cents to have it ground ?
John Mc
Fuzzybear -
I've never used a carbide chain (though I've used carbide in other applications in the steel wire industry - in the right application, it certainly does last a LOT longer than hardened steel).
How do you find a well-sharpened carbide chain cuts as compared to a regular chain? I cleaned up some storm damage with a guy who was trying out a carbide chain.  Comparing freshly sharpened chains of both types, it seemed as though the carbide cut a bit slower (I know the shape of the chips was certainly different). I do wonder how it would have compared as the day wore on.  What have you found?
John Mc
The two types of carbide chain I've seen are a regular chain with like a spray coat of carbide grits,the outher had carbide bits brazed on the teeth.The fire service uses the chain with the brazed bits to  cut through roofs and side walls.Those firefighting chains are worthless for cutting trees and limbs and extremly expensive.Every time firefighters would drill with the roof saws they would break off the carbide bits and it would cost $1.00 each to replace each tooth.Frank C.
Al_Smith
I've seen them but never used them .You can't file them as they must be ground with a diamond grinding wheel .
Prices I've seen are from 3 to 8 bucks a driver which would mean on a 72 driver 20"  loop it could be 210   to 560 dollars .Geeze I  could buy a couple rolls of chain for that amount of money .
