Author Topic: debarker  (Read 9014 times)
Offline Jaybolicious
Re: debarker
« Reply #40 on: January 21, 2012, 04:08:34 pm »
Never had an issue with overheating.   I turn it on and off before and after each  cut usually, but I leave it on continuously too and it never gets hot.  I would know if it were because I put my hand on the motor usually when I pull it back to pin it out of the way.  One thing I learned is never start the motor when it is already in contact with the log, I broke two of three teeth on the debarker bit once because it was on a hard knot when I started it, $15 bucks for a new bit.   Now I always start the motor then engage the debarker into the log and haven't had an issue since.   If there are lots of knots or if the log is very irregular, I'll only pressure wash  it as good as I can rather than risk breaking something on a knotty or bad log, this seems to be rare with the EWP I've been milling though.
Offline Magicman
  • A "Traveling Man"
Re: debarker
« Reply #41 on: January 21, 2012, 04:31:41 pm »
Welcome to the Forestry Forum Bump.   :)
Knothole Sawmill, LLC     '98 Wood-Mizer LT40SuperHydraulic   WM Million BF Club Member   WM Pro Sawyer Network
Offline Bump
Re: debarker
« Reply #42 on: January 21, 2012, 04:48:35 pm »
Thank you
Offline br549
Re: debarker
« Reply #43 on: October 29, 2015, 01:00:43 am »
I know this is an old topic. I just have to wander about the small 4 stroke generator that Tractor Supply sells of HarborFreight. I've had the TS brand one and it's small enough to sit on the saw carriage and would pull a decent sized A/C motor with a blade mounted on it.
Offline br549
Re: debarker
« Reply #44 on: October 29, 2015, 01:01:10 am »
Offline Ox
  • Trying to learn/remember something new every day.
Re: debarker
« Reply #45 on: October 29, 2015, 02:55:33 am »
Sure, why not?  With a little outside the box thinking anything like that is possible.  Another machine (the generator) to have to worry about and maintain is the only drawback I can see.
Offline tmarch
  • I'm older, maybe not wiser tho
Re: debarker
« Reply #46 on: November 25, 2015, 04:07:00 pm »
I've used a debarker alot when I ran the LT-70,it works well but I was glad to shut it off.My current debarker is an axe and wire brush,have no plans to build one of those complicated swinging buzzsaws. Frank C.
For those of us like Frank I found this tool, Shizel (google it) works well if the bark is a bit lose.  Built be Pine Ridge Tools.
Retired to the ranch, saw, and sell solar pumps.
Offline smwwoody
  • Makeing round wood square
Re: debarker
« Reply #47 on: November 27, 2015, 10:12:44 am »
Starter motors work great.  seen them many times.
I dont see what the big deal is about debarkers.  I have cut well over 10 million feet each on an LT300 and an lt3500 sitting side by side the 3500 with a debarker and the 300 without.  on average i dont see a real differance.
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
Re: debarker
« Reply #48 on: November 27, 2015, 08:06:20 pm »
     Woody, you must be getting some decently clean logs.  If you tried that with the sand-crusted stuff I get most of the time you'd be changing a band every 10 minutes.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline Chuck White
  • Sawing Mobile since 2005
Re: debarker
« Reply #49 on: November 28, 2015, 06:46:57 am »
I have to agree with nomad, you won't cut through much grit without useing a debarker of some sort!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider
Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
I LOVE MY SAWMILL
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: debarker
« Reply #50 on: November 28, 2015, 07:22:37 am »
I lived in Ga for 5 years... I could really see where you would need a debarker in that state.
Up here in Pa I dont see the need for one. We dont have the grit and sand like down south.
I have a
machine shop
Wood work shop
And a Weld shop
And now a saw mill
and a bunch of new forum friends.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: debarker
« Reply #51 on: November 28, 2015, 09:41:22 am »
  It all boils down to where you live and the type of soil on average thats there... Here you will find some nice clay, it aint very hard on blades, some really nice sand that will blast a blade in no time flat, depending on what time of year and how the logs where taken from the stump to the landing will determine if you will need to scratch some entry point on the log or not.
 It was easy when I bought my mill the debarker was not an option at the time, I could of put one on the next or so year after,but had the log wizard by then and was happy using it.
 Some of you live on sand... of course you would not live with out one... For me, it is frozen outside now... no need for a debarker from now till spring... Its windshield washer time.... :)
   Marcel
Offline Chuck White
Re: debarker
« Reply #52 on: November 28, 2015, 02:08:30 pm »
That is the key point in this area! ;)
~Chuck~
I LOVE MY SAWMILL
