Tammy and her tree of glass.
Started by Jeff, February 07, 2004, 05:26:39 PM
We have been working on a new kitchen for 2 or 3 months now. Its getting close to finished. Of course, the design has a theme of trees and forest. Even the floor tiles we found have ferns on them. I had the bright idea of leaving one of the cabinet doors without a panel so we could do our own glass work for it. I tried a faux stained glass panel which the family likes but I dont. Tonight I started on an etching process. Problem is, Tammy got roped into the tedium of it. Cutting a very detailed stencil from the drawing I did on the computer. If all goes well we will have a one of a kind glass tree when we are done. I'll post some picture when we get everything finished. Here is one of Tammy concentrating on cutting out the Tree. Glass is cheap, so we are trying several things. (only 3 bucks for chunk cut to size)
J_T
Jim Holloway
Corley5
That kitchen's gonna be too nice to use ;D ;D  Looking forward to the finished product 8)
rebocardo
I always worry about glass around my house, especially if it shatters. So, I like to use polycarbonate for projects. It is very hard to scratch and very clear. I made some windows, a bay and some double hung, from it. You can buy it cheap at U.S. Plastics and it has a higher ignite point (800 degrees) than wood (600 degrees). FWIW.
Broken glass is not going to be an option here. Tammy says so. She spent 4 hours cutting that tree out. I have a little more design work to do on the panel before we etch it. To much work in it to risk sandblast etching so we will use chemical.
rebocardo, do you have any informtion on how these polycarbonates react to processes such as etching?
shopteacher
I built my wife a bookcase for Christmas year before last and etched the glass in the doors. We have done some etching at school on some of the kids projects. Really sets them off.  Fortunitly we use a computer and vinyl cutter to make our stencils. You still have to pick out the pieces where you want the etcing to take place, but its easier than making a complete stencil as Tammy is doing.  We use a product called armoretch.  Your going to have a really nice door for your kitchen.
pasbuild
 are you going to stage blast / acid etch your glass for that 3D effect?
If it can't be nailed or glued then screw it
QuoteJeff
Well, I am not sure what you are asking. We are simply going to spead the etching chemical on the plate, wait 3-5 minutes, then rinse it off.
Norm
Very nice Tammy and Jeff, your kitchen is really going to be one of a kind. 8)
Texas Ranger
My wife, the artist, and I, the labor, have done a fair amount of etching with sand blasting.  Works well, and we get some good 3d effects, but, we use 1/4 inch glass to head off any problems.  May be too much for a cabinet door.
We got to do a project like that in Chemistry Lab class when I was in high school.  We were given a piece of glass which we melted a thin layer of wax over. Then we took some needle disecting tools and drew a picture or our name or whatever we wanted, in the wax so that the glass was bared.
We then built a Flourine generator which produced a green gas that turned into hydroflouric acid and it etched the bare glass.  It was slow and took over 24 hours.
It was a really cool experiment.
See!   I still remember some of my schooling. ;D
Mark M
You could also use a bead/sand blaster. There are few chemicals that scare me more the hydrofluoric acid. If that's what you use Jeff be DanG careful and use goggles, gloves, and rubber apron. You don't want to get ANY on you, and I mean ZERO!
It says it contains Ammonium/Sodium Bifflourides
That sounds like hydroflouric acid etching to me :P
When gas etching, stencils don't work too good.  The gas gets under the paper and leaves fuzzy lines or even allows everything to be etched.
You might have to do as we did in High School and use wax.  Even then you have to make sure that the lines are very clean.
Mark is right about being careful. Be careful ;D
I wish I were there.  It sounds like a fun project.
I am following the directions of the product. It is called armour-etch.
WV_hillbilly
  Are you going to actually use this kitchen when you' re  done .  :D  All those neat and cool things you 're doing .
Hillbilly
Were using it now. :D It was fair game as soon as the sink got installed.
Well, Its done. (the etching).  I would have been happier if it would have been more pronounced. We may try again when Tammy regains the use of her hands after cutting that stencil. :D  She likes it, but she is not quite as a picky as I am.
The bottom says "The Leaf of a tree shows us the way"
Really neat, Jeff.  How about telling us how the procedure went and the times involved.   :)
What do you think, Wildflower?  Do you always get stuck with the grunt work? :D
shopteacher
That sure turned out nice Jeff.  Tammy must have a steady hand to do all that cutting. What material did you use for your stencil?  Hey those hickory cabinets are a knock out.  Did you build them?
A. Create an image to be used for the etching on the computer, and size it for the project, then print it out. In the case of our tree, we had to make a top and bottom and join them on the project as it was to large for one piece of paper.
B. Cover the glass with contact paper (vinyl), We used a flat wood roller to work out any air bubbles.
C. Use a spray adhesive and glue your printed image to the top of the contact paper and roll again.
D. Using a x-acto with a stencil blade, have your wife ;D carefully cut out the portions of the image you wish to etch.
E. coat the entire etching area with the armour etch. We left it on for what they called for, 5 full minutes. We did this in the bath tub where we could then flood the project, nuetralizing the etching compound, and then simply wash it all in the drain.
F. Remove the vinyl contact paper and wash the glass with any window cleaner.
The etching process is really the easiest and quickest step.
Now, Does anyone have an idea how you could enhance the etching? I am wondering if a dye or ink would bond to the etched surface and not the rest of the glass?
Wildflower
Tom,
Between Jeff and I... I do what I can... Jeff is the artist I just follow his lead. And besides my hands don't hurt like his. I enjoy doing things that are hands on.
Co-owner of The Forestry Forum.
Mark M
Jeff I used to make printer circuit boards. Used some stuff called "Resist" solution. Wherever you put it the copper remained and everything else was dissolved by the acid. My kids etched some glasses in school. I think they used masking tape and a glass-bead blaster. If you are not familiar with this it is like a sand blaster in a cabinet for cleaning parts. The glass-beads, which is the "sand", bounces off of anything soft but etches hard surfaces like glass. I know there are photo-chemical processes for etching where you can get really fine detail. What you and Tammy did looks really nice!
shopteacher
Gee, I usually just take a rubber ducky in the tub with me.
   Jeff, I could try some screen printing ink. We got stuff for colth, vinyl, metal, fast dry, slow dry, water base, solvent base,  theres got to be something in there that would stick to the etch and mot the glass.  What color are you interested in?
   Sounds like were being a little mosest there, Tammy.
Fla._Deadheader
  True Artisans at work. That thing is gorgeous. 8)
  In the finished pic, it looks like there is a two tone effect. How did you accomplish that with just etching???
  NICE job.
