onan seats
Started by steve phillips, January 13, 2012, 03:01:57 PM
steve phillips
howdy all
hey thanks for the tip on the red tool box. i got the number i needed
got to pull the head off today on an onano p220 motor and the valve seat was loose as usual . but it hammered the seat stop in the block down and bad . so weld and machine time , which i do both.
  even still free motor ,may have a couple hundred buy the time it runs, not bad .
if its not broke dont fix it !!!!
POSTON WIDEHEAD
Best of luck on that engine Steve. Sounds like you got the talent to fix it.  smiley_thumbsup
Me? I would have had to hire a mechanic.
Good Luck on your project!
Steve,have you tried to find oversize seats.The block is ether al. or cast iron nether take real kindly to welding also theirs the danger of warping and loosening the outher seat.If I couldn't find an oversized seat I'd machine out the block and press in a sleeve. Frank C.
shelbycharger400
heat the metal to a minimum of 500 degrees before you start welding, then wrap in an old wool blanket, to try to avoid stress cracks.
steve phillips
howdy all
yeah im going back std ,due to the seat stop part of it broke off so figure put it back stock . all the welding is done and just a few more mins at the mill shes ready to go in. this time with about .007 interferance fit.
mean while i am waiting on parts ill start the frame for the mill
