Anyone looking for a challenge?
Started by SwampDonkey, January 02, 2012, 07:45:35 AM
I'm not, not yet anyway.  ;)
But, here are detailed plans for a wooden gear clock if your looking for something "special". :)
http://www.woodline.com/instructions/Wooden%20Gear%20Clock%20instructions%2010-2.pdf
That raises the bar of woodworking to a much higher level.  I can not even imagine the amount of time that would be required.
sparky1
Im not nearly patient enough to attempt this. I could see being half way done and it ending up thrown at a wall!!.  Im also lacking a few key tools!  It would be a great thing to have in your den for all to see though!
Shaun J
LeeB
I have always wanted to build a wooden clock. Not sure I have the skill for it though. I did bookmark the site just in case I decide to give it a try.
Lee, download the PDF in that link and always have that part at least. Websites sometimes fold. ;)
shelbycharger400
im with sparky1
atleast mine would be going up the chimney... where all my junk mail goes too, no evidence of the misshaps..lol
Oh, when you get a little older, more patient and calm down you might find the courage. ;)
logboy
I've been reading this guys blog for a few years now.  He has made some pretty neat stuff that is relevant to the clock.
http://woodgears.ca/index.html
I like Lucas Mills and big wood.  www.logboy.com
I like that sight to, you or someone else brought it up a month or two ago. I like the sled used to make a concave cut on a table saw to. Another forum I'm on have a few fellas that already use this method. Personally I never used a saw for other than a straight cut. I have made gears using his online gear program and have been experimenting with them. My problem to this point is centering holes. That will be rectified when that drill press arrives. ;D
isawlogs
 I aint got the patience to build that, no way  :D :D
   Marcel
zopi
Hmm...I keep meaning to use his calcs to make a set of plywood planetaries for a small rope machine...
Maybe when I am older amd more patient...lol
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
