Cabinet Carcas
Started by Ga_Boy, December 28, 2011, 01:20:43 PM
Ga_Boy
I need some suggestions.  I am building a base cabinet carcas that will have three openings from left to right and three openings from top to bottom (a total of 9 openings, a 3X3 grid).
The construction material will be 3/4 cabinet grade plywood, the top and bottom will fit in to the sides with dados.  Here is where I need suggestions. Should the vertical dividers be a one piece of fixed plywood (dado) with horizontal dividers cut to individual size?  Or, should the horizontal dividers be one piece?
I'll use 1/2 plywood for the back to give structure to the carcas.
Radar67
In all my years of building cabinets, the verticals were always one piece.
Regardless, make sure the base is stiffened with a cross member and the shelves have cross members or slotted into the back or the plywood shelves will sag. I would build the skeleton from solid wood and use the plywood for panels and dividers.
wheelinguy
without a doubt the verticals should be solid!
The front should be a face frame of solid wood where the vertical and horizontal members are about 2" wide.  You can put the whole face frame together with pocket screws, and then affix this face frame to the two sides.  Then, you can add the back supports and the 1/2 plywood to stiffen the carcass.
Ga_Boy
Ga_Boy
Thanks to all, I have one of the carcasses dry fitted.  Not a bad fit, the Incra fence on the router table made mince meat of cutting the dados.
I did have one casualty in th project and could not have been happier.  The coard on my circular saw got cut again (I've cut this coard about 6 six times). This time it is too short to fix, so I had to junk it.  Now I get to buy a descent circular saw, would not mind a Festool, but I am having a hard time justifying spending $700 on a circular saw.  I do like the idea of the track system.
Yeah, I keep looking at festool too.  Almost bought a random orbit sander from them, but at over $300, I decided on the 6" Bosch at half that cost.
Radar67
Look at the Skill 77. It is a heavy saw, but it is easy to cut a straight line with it. And, if they are still as good as the one I bought over 20 years ago, they last.
A have a plain old Makita here. I don't use a circular saw for accurate cuts, just to shorten up a piece of lumber to manage easier. ;)
Ga_Boy
My primary use of a circular saw is to cut sheet goods to a rough size and to do rough framing work.
The saw I had was a cheap saw to begin with, the coard was saw stiff it kept getting in the way.
I like the Makita saw, it seems well built.  Does anyone have any experience with a worm drive saw?  If they are too expensive, I may get one of these.
Most seem the praise a worm drive as a better saw. They are also heavier.
Radar67
The Skil 77 is a worm drive saw. I won't own another style saw.
I do know Lee Valley has an open house Jan 19-21 to push the Festool product line. They have blades and sand paper to under the Festool brand.
I have a bunch of Makita tools.  They are very good.  I really like the little electric Makita chainsaw around the mill.  Much quicker to use to cut rough ends or barky ends off boards.  You won't go wrong with Makita.
I've had some Makita tools for over 20 years, never replaced any of'm. ;D I don't even know if the drill I have can be replaced. It's a hammer drill, but on the trigger is a dial to change rpms. I never see that feature on new drills. Maybe it is, I never see it. Has a trigger lock and I would assume reverse is not unique.
tyb525
Skil has become a chinese knock-off brand
5quarter
Ga Boy...Did you finish your base cabinet?
Blue Harbor Refinishing
jamesamd
Festool tools are over rated IMO.Use a sturdy guide with almost any circuler saw (with a good blade,IE Freud) and the cut will be as good or better.
GB,how about some Pics of this Cab.?
Jim
All that is gold does not glitter,not all those that wander are lost.....
Next year I'm going to replace the fence on the table saw. It's pretty much shot (warn out) it seems. They have some accurate ones that use square tubing and not the round like mine.
With rock maple, it doesn't matter what blade you use, brand new, and your going to have burn. Even using a splitter.
wheelinguy
I have two milwaukee circular saws and I couldn't be happier, i've had one for over 12 yrs now and the other for about 8.  For about $130 they are great saws, sometimes I have a pieces that need to be straighter so i can put them through the table saw.  I have cut through 9/4 cherry and maple with theses saws, handles the cherry fine, burns a little on the maple.
sparky1
I love my Milwaukee tilt lock.. Im sure others are just as good, but for 130 bucks Im pleased!!
Shaun J
I'm curious, what is a Carcas ?  Maybe a typo and is something else? or is there another meaning?  ::)
Clam77
It's spelled carcass.. basically means a skeleton of something.. or the leftover shell if you're tearing down and refurbing something..   ;)
Andy
Stihl 009, 028, 038, 041, MS362
Mac 1-40, 3-25
Isn't that a place in Venezuela?
