Black Locust
Started by dgdrls, December 16, 2011, 05:27:59 PM
dgdrls
Can anyone weight in on stumpage prices for black Locust in Central NY region?
I didn't see it on The DEC stumpage report
DGDrls
woodtroll
I am not in NY but Black Locust is a low value species. May get used for blocking or pallets. I have sold some as pulp, firewood and fence posts.
It was lumped in low value species prices.
SUNYESF
A local mill outside of Syracuse, NY buys it as "scrag". $1.5 per linear foot.
dgdrls
SUNYESF,
I assume $1.50 L.F. whole log?
So a 10' log would be $15.00
DGDrls
Al_Smith
Every specific type tree has a special usage if you can just find it .As stated earlier  black locust makes a dandy fence post or just about anything that sits out in the weather .Live stock gates for example .
In colonial days they used it for door jams or window frames providing they had a window to stick in it .
There's not much demand these days for it other than firewood which it rates right up there with hickory .You could make pallets or cribbing ,that type stuff .
They also used either green locust or hickory for pins on post and beam barns etc .It would probabley make great decking for a machinery trailer too come to think of it .
tyb525
Some woodworkers love it, and it is very rot resistant.
doctorb
I find it grows and seeds itself very well during droughts.  My lawn can be brown in August with many, many little seedlings of black locust sprouting up.  I let the black locust trees on the fringes and edges within my property grow and then use therm for firewood.  Splits OK, low moisture content in the green wood.  Seems to be a little brittle though, as limbs come down often in the wind.  I have never heard of a use for black locust other than fencing and firewood, and that's good enough for me.
Phorester
In my neck of the woods black locust has no commercial value except for fence posts and a small market for firewood, although it's one of the best firewoods you can use.
Decades ago it was planted often in lawns to fertilize the grass, as it is a legume and fixes nitrogen in the soil.  Used a lot for mined land reclamation planting in VA for the same reason, plus being a pioneer plant species so it's good for recently disturbed areas.
Because of that it will seed in prolifically in abandoned fields in the bare dirt spots and especially clearcuts.  It's usually the first tree that seeds into recent prescribed burns, sprouting within 3 - 4 days after a burn in the hot spots where the ground was pretty much scorched by the burn.  One of the trees we have to do a herbicide release spray for, to knock it back so the planted pine seedlings can grow above it.
Back in the telephone company open wire days, the cross arms were treated Pine, but the pins that held the glass insulators were of lathe turned Black Locust.
ibseeker
Same in the power industry, I put a lot of locust pins up before I learned where they came from.
Chuck
worn out poulan, Stihl 250SC, old machete and a bag of clues with a hole in the bottom
Ron Wenrich
Quote from: doctorb on January 03, 2012, 08:34:24 AM
I think you'll find that the seedlings come from root sprouts more so than from seed.
Phorester
MAGICMAN;  My father had a construction company that put in underground telephone lines. Occasionally they would also contract to take down the old overhead lines that they were replacing with underground, and bring the crossarms and poles to my Dad's company lot.
One summer in my early teen's I had the job of removing all those insulator pins and insulators so the crossarms could be used for fence posts.  The stacks were way over my head. I did that for several weeks.  That was my first realization that there was different types of wood. Dad knew what the pins were made from.  I was pretty impressed with his knowledge.  Those locust pins were much harder and smoother than the creosote treated wood of the crossarms. This being my first experience up close and personal with wood products, I marveled at how they could get the screw threads into each pin.
I also remember piling those insulators into big piles.  I probably threw hundreds of those things at the pile, my goal being to break as many as I could.  All colors. Don't remember what Dad did with all those insulators. Now they sell for several dollars apiece, with price based on color.  If only we know what would be valuable decades down the road...............
doctorb
Ron-
That's interesting.  Thanks.  I'll have to investigate that more.  Certainly, there are mature black locust trees in the areas where I see the seedlings, and I never considered that all these younguns were root sprouts before.
Root sprout trees have no tap root and that is why they are so unstable.  Black Locust will completely consume clearcut areas and render them completely worthless.
Ron Wenrich
Depends on what you call worthless.  Black locust is a legume, and it is great for fixating nitrogen in the soil.  Its a pioneer species, and quickly dies off when there is competition.  I have yet to see an overaged black locust stand.  Rarely would you see one in mature woodlots.
Usually, you would see large trees around homesteads.  I've been told by old timers that they were used to keep lightning away from the buildings.  Locust worked better than other trees.
When I was in school, they took us to a strip mine where they planted black locust for reclamation.  It worked better than most and got the site ready for the next generation of trees by improving what little soil there was.
gspren
  Most of the Locust on my farm is in the steep part of the pasture where it never gets mowed and I don't think there is any in the wooded areas that were not pastured. Why is it that splinters in your hands from locust trees fester quicker than oak or cherry splinters? Those are my 3 most plentyfull firewoods.
Quote from: Ron Wenrich on January 09, 2012, 06:09:37 PM
I was referring to an area that is clearcut and will be planted with SYP seedlings.  If it is not treated with a herbicide to knock the Black Locust down, the Black Locust will overstory the Pine seedling and smother them out.
That exact situation happened on the 200 acre RMS property East of my Tree Farm.  It was replanted without spraying, and I doubt that there are a dozen Pines per acre.  A person could not walk through that worthless mess.  I talked with the RMS manager and he told me that their only option now is to bulldoze the entire area and start over.  Due to the cost involved, they have no idea what to do.
doctorb
Magic-
Are you calling my front lawn worthless?  Tell that to the tax man!
The tax man doesn't consider the acres of Black Locust that I have "worthless" either.   :-\
sandhills
I never knew they were a legume and put nitrogen back in the soil, around here there are quite a few tree lines that were planted, and I'm going out on a limb here (yes pun intended) after the thirties that have a single row of them in the middle.  Don't know if that was the reasoning or not, but it would explain it I guess.
Norm
I have 5 acres of black locust that took over what was most likely pasture. When we logged it the trees looked to be 40-50 years old. Within 7 years you could not walk through it due to the suckered BL that came back. I spent 3 weeks with the excavator plucking those out so this could be farmed. Within a month I had starts that were at least 3 ft high. I disc ripped it this fall and will farm it for a couple of years to kill them off so it can be turned into an alfalfa field.
Al_Smith
Locust is pretty invasive .I think just about as bad as osage orange .Except osage doesn't seem to colonize  like locust .
You can mow it off with a bush hog and given enough time it will go away unless it's gotten too large for the mower .
They used to propigate in fence rows  but those are all but gone since the raising of livestock is not as it was back in the 60's in these parts .I've seen 30 inch ones but those were pretty rare even back in the day .I'd imagine about 16-18 inch would be considered a large one .
Ron Wenrich
I've had a few come into the mill that are bigger than that.  They're generally rotten or split.
Al_Smith
As a side note and not a black locust  ,the trimmers dropped off a few years back some giant  oak  rounds and one honey locust that was an astonishing  48" in diameter .
The oak was a tad over 3 feet and not a problem .The honey locust needed the aid of a skid loader .Fact some of it has yet to be burned in the stove . Good stuff,tough to split though .If it turns cold enough I'll burn it .About 4-5 cords of the stuff stacked .
Ron Wenrich
I had a batch of honey locust brought into the mill.  The loggers couldn't figure out what it was.  It made some really nice wood.  I have about 800 bf of clear in my barn.
They used to plant honey locust around pasture edges.  Seems that the bean pods made good cattle feed, and came at a time when grass production was down due to the heat of summer.  It also gave cattle some shade.  The ones that came to the mill were the thornless variety.
"the thornless variety"
I don't have that variety of Honey Locust.  Mine all have tractor tire punchers.   :-\
Al_Smith
Oh yes indeed .A honey locust grows thorns that look like small elk antlers .They'll go right through the soles on a pair of tennis shoes too .
limbrat
the cows might like the seed pods but the deer love them. the does i was watching seemed to like the pods from some trees more than the pods from others.
ben
They eat the pods but sadly most of the the actual seeds pass through and are deposited in a pile of fertilizer where they quickly sprout and grow.   :-\
Al_Smith
That's just typical of a pasture field in an area that once was wooded . I forgot the actual term but it indicates  the cleared ground is attempting to revert back to wence it came .It this area fallow ground will pretty much resprout in about 15 -20 years .
Cattle won't do much in the order of preventing new growth  .Perhaps a herd of goats might but it's nearly impossible to fence in a goat if it makes up it's mind it wants out .It doesn't make much sense to spend thousands of dollars to fence in 50 dollars worth of goats either .
Phorester
There's a thornless variety of honeylocust , called, oddly enough..... thornless honeylocust  ;D  developed as a yard tree.   The house across the street from me has 2 in their front yard about 30" dbh and 70 feet tall. Very pretty.
Norm
I do see some that are not quite thornless but not many on them. Others look like a porcupine.
I going this week to pull some black locust I put down with the excavator to use for siding on a smoke house I'm building.
Al_Smith
Actually they planted a bunch of thornless locust to replace aging silver maple on some of the  in town streetscape  trees perhaps 20 years ago .Unfortunately  they also planted ash trees in addition .Well, seemed like a good plan at the time at least .
FARMERw/o FARM
We had a locust grove on the farm and Dad cut post in the winter. When I was 5 yrs old I'd take a thermos of coffee to him mid morning. Later, in my teens, I cut them with the single man's saw. Then I bought a couple of chain saws with the money made from fence post! I'm 63 now. Pressure treated posts today. Locust posts gone the way of buggy whips pretty much in my world. Please prove me wrong!
ID4ster
I know that there is a place (woodlot) just outside of Addison, NY that cuts and sells several hundred black locust fence posts a year off of their ground. They've got a consistent market from the grape wine vineyards just north in the Finger Lakes region of NY. The black locust poles are used on the ends of the trellises to keep the wires tight and secure the entire arbor. They are very rot resistant and are very much in demand within that industry because they don't need to be treated. Depending on the size of your trees you might be able to do something similar if you have a nearby market. It also makes good foundation timbers for putting directly on the ground for people that put up temporary cabins or cabins on skids that they may want to move around later.
Bob Hassoldt
Seven Ridges Forestry
Kendrick, Idaho
Want to improve your woodlot the fastest way? Start thinning, believe me it needs it.
davidv
Black locust is a close second to osage orange in my area for making bows. Many bowyers in the northeast make their best selfbows out of it.
