Can Someone Please Explain Log Rule Scales ?
Started by DR Buck, February 01, 2004, 05:46:41 PM
DR Buck
 :P
What "log rule" is most often used by the custom sawyer?  And if a 'board foot' is a standard volume of measurement, why so much difference between the scales.   ???
I cut two 16 ft  maple logs yesterday. By the "Doyle" scale there was 74 bdft.  By the "International 1/4 Inch" scale the same logs had 130 bdft.  When I finished cutting I had 169 bdft of lumber.   :o
Looks to me if I'm going to estimate a job, I should use the International 1/4 Inch scale.  Is this correct?   ???
By the way, the maple logs were my first boards.
DR Buck
Thanks Jeff,
The explanation from the linked web page clears things up.  I thought it was some kind of "New Math".
woodbeard
What size log does the Doyle scale accurately represent? In other words, when does it stop underestimating, and start overestimating?
Around 30 small end diam. inside bark.
Try it in the calculator for a 16' log.
