PH260M3 on order. Profile Knife question.
Started by DGK, November 27, 2011, 09:08:23 AM
DGK
After not posting for a while, I am back and with a new machine. Just ordered a PH260M3 - 3 Phase machine. Last year at this time I was waiting on the PH360. Times have changed over the past year so as a result, the 260 now suits my needs. The question that I have today is about profile knives. With my order I get a 1000 dollar knife credit which I can spend on knives and accessories. I have a few profiles in mind for some of the projects that are upcoming. I would like to be able to S4S standard 2 by stock with a radius edge. Do most of you use the radius cutter on the horizontal cutter or use the radius cutters on the vertical cutter? The benefit that I can see about using the horizontal radius knife is that you could use it on multiple thicknesses as opposed to only one. Any thoughts and/or comments would be appreciated. Additionally, if you could share information on your most used cutter profiles.
Doug
Yukon, Canada
LT40G38 modified to dual pumped hydraulic plus, HR120 Resaw, EG200 Edger, Bobcat S185,Bobcat S590, Logosol PH260M3, Sthil MS660's, MS460,MS362's MS260, Trailtech dump trailer, F350, F700 Tilt-Deck log/Lumber Hauler, JD440B Skidder, Naarva S23C Processor
BandsawWarrior
Look into a set of side cutter heads that take the carbide inserts.  Each carbide insert costs around $30 and will need a steel backer but it will last 10 times longer that HSS.
People always want some kind of 1" T&G, 2" T&G, 5/4 radius edge for decking, back relief for flooring, and some kind of chamfer for facia.  And like you said knives for S4S for trim and such.
Tyler Hart
T&N Custom Sawmill
DGK
Doug
Yukon, Canada
