Log splitter?
Started by bama20a, November 26, 2011, 09:39:10 AM
bama20a
Hello All: Hope each of you had a GREAT  Thanksgiving,
My Question is,I have a 20 ton log splitter that the motor is shot(6 hp brigs),Would a 5 h.p. Honda be bigger enough.I have found one on CL,Also what would be the right size motor for the log splitter?
     Thanks Mark,,,,,,,,,,
It is better to ask forgiveness than permission
Buck
I had  a five hp briggs on a 22 ton mtd. worked fine. That honda oughta do fine. I recently ordered a new 22 ton Iron & Oak that is coming with a 5.5 honda.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
sawguy21
The Honda will work just fine. Make sure the shafts are properly aligned and that there is a bit of clearance for the coupling spider.
bama20a
Thanks fellows for the comeback,I've left a message for the motor. now just waiting for him to get back to me.
Jack72
I have a 20 ton with a 5.5 honda         I could be wrong but it helps having a two stage pump (which mine has two stage 11GPM pump)       to get through those tough pieces that will kill your motor instantly having a single stage pump
13 Chevy Duramax
Stihl 046 036 009
Northern 25 Ton Splitter
