kiln cart construction
Started by Dan_Shade, November 22, 2011, 08:46:50 PM
Dan_Shade
I'm preparing to build a kiln cart, Nyle recommends using 3x3 oak for the cross members, does this work pretty well with the cycles of a dry kiln?
lots of dull bands and chains
Ga_Boy
Dan,
Look on BBTom's web site.  He (al least he use too) have pictures of is kiln carts.  Mine were based on his design.
JV
I am planning a building and drying chamber this coming spring for a Nyle DH kiln I recently purchased, so I have a lot of questions.  I couldn't find photos for the carts mention built by BBTom.  I did find some posted by OWW in his thread "Time to stop being a wannabe".  I did find this .pdf file that gave me some ideas along with making the fan deck and fold down baffles.  I am planning an end loader for 24' long lumber stacks.
    http://ucanr.org/sites/WoodyBiomass/newsletters/Hardwood_Handbook36233.pdf
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Ironwood
I still have a TON of kiln wheels for sale,
https://forestryforum.com/board/index.php/topic,36475.msg527356.html#msg527356
Advantage is you can put flat bar stock on your floor and still drive over itt with even a small hard wheeled fork truck VS. the inverted angle. Depends on how you wanna organize your space.
Ironwood
Ga_Boy
JV, youi are right, I looked on BBTom's web site and his pictures of his kiln build are not there anymore.
I used his pictures to base my carts on.  They worked well.  I did opt for the "V" grooved wheels on one side.
The one thing I should have done differently is adding a cable and pully system to allow me to pull the cart in to the kiln.  This is much easier than pushing the cart in with a front endloader.
scsmith42
Dan, my first kiln carts were made from oak.  Before long, I replaced them with carts made from 4" channel with the v-groove wheels and steel track.  I built them based upon Nyle's design.
My next kiln will not use carts.  Instead I will fork the lumber into it from the side and place it on wood bunks such as 6 x 6's.
Loading and unloading carts, IMO, is too time consuming.  Also, there are air flow challenges when using a narrow kiln.
Tom's 3638D Baker band mill
