maybe disaster for my business, trying to turn opportunity...advice?
Started by zopi, November 21, 2011, 08:31:31 PM
zopi
Have been having some problems with my left arm...going to the doc this week, have to, was on a job this morning trimming shrubas and it was all I could do to swing the trimmer...big problem for a guy who runs a chainsaw almost full time...probably it is just tendonitis, or worst case, a torn rotator...just do not know..
Anyhow...I made a half smart remark the other day on facebook about going out to Occupy woodshop, and did anyone want anything weird made of wood...and promptly got five orders for various things...cutting boards, shadowboxes, and a couple of schoolhouse paddles (I chose not to ask...but I do have some weird freinds...life is more interesting that way..) and I figured since work is slow, I may be able to put out a few projects on ETSY and ebay, and maybe a couple of local places...so the wife and I have come up with some simple things that seem to sell, bread and cheese boards, birdhouses made out of log sections, branch section wooden buttons (knitters love them)
Does anyone have any other ideas for simple things that go together pretty quick which might sell? My major tools...tablesaw, bandsaw, radial arm, router table, forty inch lathe, amd of course a sawmill...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Sprucegum
There is a local crafter who makes simple stools, benches, and small chairs out of planed boards. He sells them unfinished and even unassembled if you wish. The buyer puts them together, puts on a finsh and "Eureka! did it all himself"  ;)
zopi
That is a really good idea...and gives me another idea...rustic milking stools...good for sitting on, a place for your garden gnome, potted plant, or on the off chance, you could perch there and milk a cow...
Looks like large turned candleholders sell ok too.
Got Wood?
And lots of junk.
Bibbyman
At one time I sold a bit of lumber to a taxidermist that used the lumber to build bases for his full body mount displays, etc.   From him I got the idea I could make trophy mounting plaques.  We had a lot of kiln dried lumber that would only make sort pieces.  So I'd glue them up 18" wide and 2' long and run them through the plainer.  I was working as a designer so I had access to a CAD system and plotter.  I made a series of shapes – including the shape of Missouri.  I made maybe two dozen large size and as many smaller ones for antler mounts, etc.  He sold them at his shop and didn't mark them up – saying it was a help to him having them available.  His customers like that they were wider than what was available.  The shape of Missouri was popular too.  I made them in oak, walnut, etc.  The most popular turned out to be eastern red cedar.  He sold every one of them.
Sawing since '94
redbeard
Garden tables, its a garden with four legs easy to build and sawmill wood really makes them strong. Folks like to stand up and work in the garden these days. Haven't built any yet but saw alot of them on CL.The log house looking bird houses do well also.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
zopi
I like the taxidermy idea...will check around and see what we have locally..
The garden table seems interesting..I will have to investigate how to go about marketing them...maybe something smaller for now...potted plants are pretty poplular here, as is anything that looks remotely colonial, so maybe rustic plant stands with rough finish and distressed...
The birdhouses I am making are pretty simple...put a section of log on the sawmill and take a slab, pull the log and cut into sections, hollow out the center, leaving a bottom, drill a hole for drainage, bore an inch amd a half or quarter hole in the flat face...and a half inch hole below that for a dowel perch, nail a chunk of sawmill slab on top and hose it with poly...
Got Wood?
And lots of junk.
CHARLIE
I sell on Etsy and one of things I watch is not to try and sell something that would be a PITA to ship.  Another thing is not to sell something where the shipping cost will exceed the value of the item.
Why not sell different sized boxes made from different types of wood.  A box can be as simple or as complex as you want to get. It seems everyone loves having boxes.
Charlie
zopi
Charlie, have thought about boxes some...and will probably work up to that...I want to learn how to cut a decent box joint..I understand the Idea, just never got around to learning how...some of the figured woods I happen across would make nice jewelry boxes...and of course there is always the red cedar boxes and chests.
I need to build a couple of bee hives anyway, as my keeping mentor is going to kick my butt if I am not ready come spring...he is already mad at me because I want to use top bar hives...I compromised with him, amd will use kenyan tbh's as opposed the the tanzanian hives...so then at least we can swap frames when needed. Anyway, will use that as practice cutting the box joints.
Got Wood?
And lots of junk.
zopi
Project for this week will be to get a small kiln or two put together...the first is likely to be pretty simple, maybe four or five hundred board feet, and then a thousand bdft solar kiln...although that may have to wait a bit.
Got Wood?
And lots of junk.
CHARLIE
Box joints and dovetail joints are really nice, but if you are planning on selling volume, you should be looking at joints that look nice but don't take a lot of time.  Think miter joints with feathers of contrasting wood to lock them into place. Even some butt joints could be attractive and would work for things like pencil boxes or wine bottle boxes.  Make boxes using your miter saw or cut mitered or lock mitered joints using your router.  Figure out a design that looks nice but is not labor intensive.  Just my thoughts.
Charlie
jim king
Crotch wood and burl turning blanks sell very well.  I have sold large burl slabs also for taxidermy mounts.  I would think large crotch slabs would sell well to taxidermists also.
zopi
I have been digging through my collection of fine wood working...I have twenty five or thirty years digitally, and hunting for simple things...that does not work too well, easy to get side tracked. I spent this morning early making my first hand cut through dovetail...read an article how to from 1976 that took all the stupid out of it....wish I had seen it last decade...my mom is putting together a little herb tea business, and I am looking at the idea of making boxes for her gift sets....
I am trying to organize the shop a little better, and next up, i guess I am going to learn box joints...
Got Wood?
And lots of junk.
red oaks lumber
zopi,
the problem with your shoulders sounds like bursitis, inflamtion of the bursa sac the only cure is rest, by that i mean change your work habits.right now both by shoulders cant raise any higher than straight out.working in your shop should help fix the shoulder. good luck
CHARLIE
I use Google Image for a lot of ideas.  If I want to turn a Finial, I'll search Google Image for Finials or Drop Finials. If I want to turn some bottle stoppers, I search for pictures of them. I don't copy anything but the pictures sure do stimulate the brain.  I might combine a couple of ideas too.  Do a search on Wooden Box and see what you get. When you build 'em, keep 'em simple and affordable to the majority of the people.  Keep track of your material costs and your time.  I want to get $20 per hour for my time so if I can build something from "beginning to end" in ½ an hour, I'll price it a $10 plus material cost.  Don't short yourself unless you just want to do someone a favor.
Charlie
redbeard
Left Coast Chris
Raised bed gardening is very popular also.  If a person could develop a kit that locks together easily and is strong it would be likely a good seller.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Norm
zopi
Hmm...my last post seems not to have made it...anyway, thanks, guys.
I am making some progress with the shop iself...trying to get all the odd bits which have nothing to do with woodwork out and get the lumber that I have just stashed there used up..most of it is ERC and jap red maple, odd offcuts...it is amazing how much one can do in a tewlve by twelve shop, and equally amazing at how fast the useable space goes away...especially with full sized tools...I am fortunate to own some really good tools..my grandmother bought me a Rigid contractor saw when they still made tools in this country, and I got one of the last american made Rigid bandsaws produced (eight years later learning how to actually use it) an ooold Delta lathe...we figure it was made mid fifties...I need to make a faceplate for it..or scare up a decent chuck...
One thing I have to do is build a saw till for my collection of handsaws...nothing spectacular, but some good saws, and I like having them where I can see them, but they take too much wall space up.
Meri has me making her some pen blanks to try and sell, so I cut some quartersawn out of a white oak sawmill slab last night...set the sap out of them and they are drying in my micro kiln (80 qt commercial dehydrator) which mkles quick work out of small stuff like that, even white oak..
Some body above mentioned turning blocks, which remi.ded me, I have a trunk of a norway maple out back which is largely spalted...need to take the chainsaw to that and get the blocks out and coated.
Some thing I am going to try, since sweetgum is such a pain in the butt to cure in lumber sizes, i am going to experiment with it a bit and see how  it willl work for pen blanks....it is pretty wood.
Got Wood?
And lots of junk.
CHARLIE
Zopi, many years ago I got a Oneway Stronghold 4 jaw chuck. It's one of the best decisions I ever made.  I use it a lot and rarely if ever use a faceplate anymore.  If you don't want to spend the money for a Oneway brand, take a look at Penn State Industry's Barracuda chuck.  I don't make too many pens because everyone else already does, but I do make them for gifts and once in a while a customer will request one.  I purchase my pen kits from Penn State Industry's too. They've always given me good service.
Charlie
Riggs
My Grandfather builds urns and sells them to local funeral homes...
Every man's life ends the same way. It is only the details of how he lived and how he died that distinguish one man from another.~Ernest Hemingway
Norwood ML 26
zopi
Charlie, one of the things I <really> want a chuck...just no money for one...someday...I have a customer who wanted to sell me her late husband's lathe...gonna go back and talk to her about that...big nice variable speed job....might can work a trade. For now, I think a faceplate will work out...might make myself a spike mandrel for turning bowls...
We have a local funeral home, and urns are something I have given passing thought to...have seen quite a few for pets....I am not sure that my craftsmanship is there yet though....
Got Wood?
And lots of junk.
Brad_S.
Quote from: Riggs on November 24, 2011, 09:26:34 PM
Along these lines....pet caskets. Small, easy to make, cheap to make if you have a sawmill and can cut your own lumber. Size means you can utilize common lumber.
zopi
Lol...I will ask if the local funeral homes have any demand for such..
Sawed out some bradford pear pen blanks this morning, amd turned a couple of samples...too plain for my taste, but what a wonderful tight grained wood to work with!
Got Wood?
And lots of junk.
POSTON WIDEHEAD
Take a look through the WOODWORKING section on the forum. Man....there is some good looking stuff on there that may give you some ideas.
CHARLIE
Pens have such a small amount of wood that the wood really has to have some character to it to grab a person's attention.   If you are going to use a plain piece of wood with not much character, then you can add a little pizzaz of your own.  You can dye the wood a color using analine dye.  The colors available are almost endless and you can have a bright red pen, a bright yellow pen, a bright green pen, orange or blue........  Or you can put a little interest into the pen barrel by adding a Celtic Knot.
This link is to Wood Magazine which has an article about making Celtic Knots on the lathe in issue 177.
http://www.woodmagazine.com/woodworking-tips/techniques/woodturning/turning-pens-into-cash/?page=7
This link is a video making a celtic knot Ornament.
http://marleyturned.com/Video_Celtic_Knot.html
Charlie
