Drilling 1/2" Ø hole into wood on 30-60° angles.
Started by SwampDonkey, November 20, 2011, 07:03:38 PM
Is there a jig for this, or would a bench drill press tilt to do it? I don't have a drill press, yet.
I want to make a wooden wheel about 6" diameter, 2" thick, with 5 spoked handles set into it 30-60°. Not yet sure of the angle, but that's the ball park. The insert of the handles would be 1/2-3/4" Gotta make two wheels.
Thanks if you have any ideas.  ;)
I would try it by tilting the table on the drill press, but there may be a better way.
sprucebunny
I've done it by starting the hole straight and then turning to the angle you want. You can make a guide for the angle out of the scrap you will want to practice on  ;)
You can also buy guides or make one out of hardwood by drilling the hole straight and then cutting the block at an angle to the hole. It will start better if you start the hole straight then clamp on the angle guide.
As sprucebunny says, make a jig to get good repeated angles, depth of holes, and handle position.
IMO, it will be well worth effort if you want the handles to look similar on both wheels.
Yeah, that's the goal to get evenness. Thanks for the suggestion spruceb. ;D
shelbycharger400
well... my case here...
my drill press is a 1950's , it was a 3 phase industrial, switched to a 1/2 hp motor on it, needs more but its ok.
anyway, the table on mine is 16d x18w with t slots in it, and a coolant slot around the outside.
my table dosnt tilt. Pay attention to the following...
I bought a used rotary table, i need to shim it cause it has slop..no worries their for me.(ill do it sometime this winter)
clamp rotary table to press table.
use t bolts in the 4 slots on the rotary table... clamp wheel for face drilling,  if your doing angles, look for a used dividing head, last one i found local was going for 300.  it will do anything from 0 to 90 deg.
with a standard rotary table, i could use a sine bar, but i would have to mark all holes first, put the sine bar in, drill, reset ..ect.
i paid 60 for my rotary table.
remember:
360 deg = full circle
so 5 spokes = 360 /5 = 72 deg.
putting them in without a dividing head gets complicated fast, but it can be done just have to do the math. precision micro bubble level (think 1 inch long) are the cats meaw!  look for caddy or 94 vintage dodge lhs/concorde/vision headlights have them too.
T Welsh
SwampDonkey,I was thinking on the same lines as shelbycharger400, Drill press is your best bet, drills do one thing and work one way, I would lay out the hole pattern on the piece and make a simple wood jig to hold it where you need it in the press or for that matter a hand held,I build jigs all the time when I am faced with a need and no proper tool or machine to do it. Tim
Bill Gaiche
Take a piece of hardwood and drill the angle you want, then clamp the wheel to your work table with the piece of hardwood with the hole drilled at the angle you want next to it and clamp it also. Now take your drill and drill to the depth you choose. Rotate wheel and drill again, bg
Yup Bill. Just gotta aline the hole toward the wheel centre. :) But if I get desperate, I see a nice floor model drill press with tilt and swivel for $450. ;D
T Welsh
SwampDonkey,If you look around in the paper for auctions you can find a drill press for 100 to 200 bucks,thats how I found mine!
Oldie but goodie. paid 125.00 for it. Tim
Burlkraft
Quote from: SwampDonkey on November 22, 2011, 06:48:14 AM
That would be a long wait in these parts. ;D
You need some different parts  :D  :D  :D
Why not just 1 pain free day?
Phorester
I have a 3 year old floor model (not bench-top) Delta drill press with a table that is adjustable for tilt in every direction.  It absolutely will not move when you lock it down and drill.  Very precise, very stable. Love it for precise drilling at angles.
Git one.   ;D
I'll probably end up with one sooner or later because I have a lot of precise drilling to do with this one project alone.  ;)
Anyone know of an online source for ratchet wheels? Ideally it would have a 1-1/2 to 2" square center cutout with mounting screw holes on the face. And the sprocket would be 5-6" diameter. Of course need a pawl. Need two pair of wheels/pawls. ;D
You'd be surprised how rare they are on the internet. :D
Gary_C
Don't know if you have them, but rim guided or forstener bits are the best for drilling at angles to the surface. But a good set of those aren't cheap.
JV
You could get a couple of scrap gears and cut or have someone machine the square opening.  The pawls could be made from flat stock with a little cutting an filing.  Depends on the load you are trying to move or hold.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
shelbycharger400
gary....
on the forstner bits at angles....
i once was drilling a leg for a table...clamp wasnt holding the log very well... so i used one hand... i was using a irwin 2 3/8 i think., i took out the auger center because it bites too fast, using my 1/2 chuck dewalt,   it cut a little...then walked FAST..  I got bit between the thumb and index.   I wont do that again... next job im making v blocks, and now  i have 2 spot drills for the center, one short and one long.
shelbycharger400
Gary_C
Quote from: shelbycharger400 on November 22, 2011, 09:53:32 PM
Good point.
Holding a hand held drill steady while drilling large holes is problematic with most types of bits and especially rim guided ones. If you are drilling at an angle with any type of bit, you should be using a drill press or a good fixture.
Yeah for sure, they can take a lot of meat off your digits in a hurry.
Yeah those are tiny clock gears Shelby. ;D
I might see what a CNC shop can do. I live near a lot of small metal shops here in farming country. They make them for crank ups on bin piler conveyors, so can't be too hard. I want a lot of teeth on the wheel for slow advancement.
JV not much weight, maybe 20 lbs.
JV
If you have an old ag salvage yard, some machines could have lightweight thin gears.  Machine gears such as lathe change gears show up on eBay and are of lightweight material for the older smaller machines.  A machine shop should be able to make them if they have at least an index head and a fly cutter.  Motion Industries or Motion Canada distributors should have gears, if you don't have to take out a loan to buy them.  An industrial supply handling Boston gears should have a wide range of gearing.
John
Motion is 25 miles from here. I know bearings there are a lot cheaper than Stihl. :D But I think I'll stop into a shop about 5 miles away first. They have all kinds of expensive machines sit'n around hardly used. Give'm something to play at. ::)
The racket wheels will mount on the back of these maple wheels. I have to cut the centers out in the maple and mount turned handles. These are 8" Ø, 2" thick. ;D
terrifictimbersllc
Two armchair suggestions, never did either one myself.   Spoon bits are supposed to start and drill at any angle.  Alternatively, cut a disc on the bandsaw or turn it on the lathe with the desired angle.  Now drill into this at 90 degrees easily perhaps with a jig on the drill press or even on the lathe using whatever drill bit you like (can use indexing on the lathe to get the right spacing).  Now turn the outside edge back square.  The holes are now at an angle.  If they're not deep enough now it's no problem.
