Cajun Girl Helps Clean Wild Pig
Started by cornbread, November 10, 2011, 07:47:56 PM
With that many hands it's a wonder that someone did not get cut.
Dan_Shade
lots of dull bands and chains
Texas Ranger
Cajuns have the skill of a surgeon when it comes to dressing food game.
Also, the first time that I have ever seen a filet knife used for skinning.  Cutting from the "hair side" is a bad idea.  I always cut from the inside.
ellmoe
Quote from: Magicman on November 11, 2011, 06:43:35 AM
  That, and too many knives (hands) in a small area, is what I noticed. Besides getting hair on the carcass, with all the sand usually found on a wild hog, it's a good way to dull a knife. Maybe they have only skinned a scalded hog before.
Buck
Yeah, I like to get in under that tough skin. I also use utility knives on hogs now. Just swap the blades and keep working.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Texas Ranger
Given the opportunity we also pressure wash before skinning.   Lots of stuff on hogs down here that are not good.
WildDog
I wouldn't want to be paying the 3 of them by the hour.
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
iffy
iffy
Make us a video to show how it is done.
shelbycharger400
iffy
Quote from: beenthere on November 14, 2011, 04:56:34 PM
iffy
Would love too but don't have any dead hogs right now. Of course back when we butchered everybody rendered lard so my grandpa would have skinned me alive if I wouldn't have skinned close to the hide. And like Magicman said, you don't cut thru the hair to slice the hide. The way the saw was being used should have pretty well scrambled the insides. Of course we skinned and saved the head too. And on and on ------------ ;D
Woodchuck53
Evening all. Any one else use compressed air or hp water to inflate the hide from the body and cut out from there? We used to harvest several at a time from our soy beans when I was younger and that was a quick way to get them processed.
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
WildDog
QuoteAny one else use compressed air or hp water to inflate the hide from the body and cut out from there?
Not for pigs, but I have been meaning to give it a go on goats.
LeeB
how well does it work on hogs? how much fat and meat come away with the skin?
pineywoods
The air hose trick works on humans. I had a not-so-bright guy who worked for me. He was cleaning some greasy parts and cut his hand on a sharp edge. He grabbed an air hose and turned it in the cut to clean out the grease and gunk. Blew his hand up like a balloon and peeled the skin off most of his hand.
Found a vid using the air technique on deer. This was an ad peddling a set of needles, but the vid shows the procedure. Looks like it would work quite well (for hogs too).
http://www.youtube.com/watch?v=xEJfBZAbtPU&feature=related
Texas Ranger
We skin them with a four wheeler and a rope, seems quicker than that, and  you still get the whole hide.
CLL
Yep, cut below hocks, put tennis ball in hide, tie a rope around it and pull hide off.  CLL
Too much work-not enough pay.
