Sawdust on lumber and cants
Started by woodsy, November 08, 2011, 06:43:49 AM
woodsy
How do other folks go about removing sawdust on your lumber and cants as you're sawing?  I run a bandmill and there is always a degree of sawdust on the boards and cant after the cut.  Sometimes it's packed on and sometimes it's loose but it always requires some degree of manual removal by me either during sawing or prior to sticking the lumber.  I have just lived with this and it never really bothered me too much until recently.
I know feed rate and lube rate can have an effect on how saw dust is cleared through the cut. Just wondering how other people deal with the saw dust.  Any good ideas besides scraping and brushing with putty knifes, brushes, levels, compressed air, etc?  I would assume board returns and rollers help with removal. How about an air line that clears the cant of sawdust as the carriage head is returned?  Has anyone done this?
LT40HDG38, Logrite T36 log arch, 42 hp Kubota, 6 foot cross cut saw, lots of axes and not enough time
Woodsy, we pretty much have to live with it.I use wick applied diesel/oil mix not enough to effect the sawdust just put the board on edge and bump it most dust falls off.Prehaps your using too much water.Air would work but then you'd have a cloud of fine sawdust in the air to get in your eyes or worse explosive.I'v never had a customer complain about it.There are things you can due to reduce it but not eliminate it. Frank C.
Chuck White
I agree with Frank!
The offbearer turns the board on edge and just bumps the board on one of the bunks and most of the sawdust falls off.
Another option would be to flip the board a couple of times while it's still on the bed.
paul case
That works for me as well, but I have learned not to do this on logs with shake. The bump may crack the board. If it is a customers log, it would ve my fault for ruining their highly valuable lumber.
However if it is mine, I would rather it crack or bust as close to the slab rack as possible. ;D  PC
pc
Kansas
We never really worried about it, outside of some crates we build for a company that want the boards swept off. We never have gone out of our way to get rid of sawdust on kiln dried lumber. I can't see where it hurts anything, but then we air dry everything before the kiln, and it has been known to be windy in Kansas. I know they make dedusting machines for pallet boards. I also know they aren't used often, at least as far as I can tell.
bull
ely
i sweep all my lumber because the sawdust slows drying and attracts insects. i reccomend all customers sweep their lumber before they sticker it.
T Welsh
I use bandmiller2 and Chuck White, method! Tim
OneWithWood
I use a rat tail brush to sweep the board as I am milling.  This helps me to see impending defect so I can turn before I hit it.  When I am not sawing for grade and sawing a cant through and throug I use a piece of braken blade as a scraper, scraping off the sawdust as I transfer the boards to the kiln cart.
One With Wood
YellowHammer
I nicely ask my wife to slam the board down harder on the mill rails before she stacks it.  Somewhat dangerous but it works. ;D
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
eastberkshirecustoms
I see that Cook's now offers a hydraulic rotary brush attachment to remove the sawdust. Might make for an interesting home brew mod, just remember the pics.
Piston
I've used a small stiff broom, but it's not really a great method  :D
I like the rotating brush idea
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
Knute
I just use a broom also and sweep both sides as I sticker and stack.
backwoods sawyer
An unscrambler will do wonders for cleaning the saw dust off the boards.
Backwoods Custom Milling Inc.
ljmathias
With fresh cut SYP, sawdust is full of sap and sticks to the boards bad.  I scape each surface with a piece of broken blade, otherwise there's sticky sawdust getting on everything (mostly me) while I move boards and sticker-stack them.  Plus after they're air dry and pick one up to use for something, all that sawdust left on gets on stuff worse than when it was first cut.  Knocking it off before drying just doesn't work, and I've tried a brush- just makes the bristles all stuck together with gooey sawdust.  I love pine!   ;D
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Radar67
I just stacked 1000 bdft that MM cut. I used a broom and wire brush like MM has pictured to remove all the dust before stacking. It adds a good bit of time to the job, but it sure beats mold and loose saw dust when you get ready to use the material.
Banjo picker
MM are you sure that middle brush works well?   :D  Tim
I am a push broom guy too.  Sweep both sides.  I am with Ely about the improved sawdust and bug management.
Quote from: Banjo picker on November 13, 2011, 07:25:58 PM
Just so you will know that my brushes get used.  You will also notice which scraper is the favorite.   ;D
stumpy
I use a 12" wide drywall paste knife.  It's just a large putty knife.  It's quick and works great.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
That is a very good idea.   :)  I have one in the shop that I will put in my truck.
Qweaver
This is only a problem for me when the temps are well below 32 and the saw dust just freezes to the cant.  I usually knock it off with the edge of my framing square.  I'm sure there is a better way but it's what I have on hand.
250quality
12" drywall knife is my kids favorite tool here as well. Barely even need to sweep after a scrape with it.
Banjo picker
That would be a good use for it, because I hope I never use it to finish sheet rock again. Tim
