Oops
Started by Bill Gaiche, October 08, 2011, 06:32:51 PM
Bill Gaiche
The claw got scratched back today. But ruined bandsaw blade. My first signature on claw. Maybe I will remember to lower it next time before I start sawing. bg
Banjo picker
Sad to say , but you will most likley do it again. :(  Tim
JP135
Dang it!
I guess its kind of like a buying a new motorcycle. Before you leave the dealership, drop it on both sides and get it out of the way.
sawguy21
zopi
Oops...good one though...impress me...get one like that on the back side...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Congratulations Bill. :o  Very nice indeed. ;D   Remembering the next time is not the problem.  Remembering all of the time is the challenge.
paul case
character marks.   pc
pc
millwright
I thought that I was the first one to ever do that, I did mine yesterday with the first cut on a brand new blade.
T Welsh
tried to skim past the back rests today, got by this first one and didnt make it past the last one, skimmed the bottom set on the teeth only! go figure! Tim
You need to make a slight adjustment.  If it misses the first one, it absolutely should miss the last.
Bill Gaiche
Then I am in trouble if it requires me to remember all the time. bg
 :D :D  That is why it is a challenge.   :)
Paper Maker
   Was anybody watching? ;D I was cutting a 18' white oak for someone yesterday and forgot to lower the front toe board. Needless to say I cut a wedge. What can you say. It was frustrating to say the least. Live and learn.
Bill,
At least you did a good job of it.  No point in just nicking it.  If you are going to do something, you may as well do it right  :D.
Bill Gaiche
Nope, nobody saw it but my camera. bg
Papa1stuff
If no one saw it ,it didn't happen :D
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Nomad
It did once he took a picture of it   ;D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Chuck White
We've all (or most anyway) hit iron Bill.
You really did a fine job, should have been enough to get it out of your system.   ;)
Could have been one of those "sawmill gremlins", they're pretty sneaky.  >:(
Cedarman
Quote from: millwright on October 08, 2011, 08:30:40 PM
Millwright, I always do it with the last cut the blade ever makes. :D :D
jueston
Quote from: nomad on October 09, 2011, 07:24:22 AM
just maintain to the end "it came like that!"
:D
dovetails
Quote from: Cedarman on October 09, 2011, 08:21:21 AM
Thats a fact! After cuttin the top of a backstop to a nice taper, the blade didn't even have teeth left on mine! Who says ya can't cut metal with a wood blade!
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
paul case
Quote from: jueston on October 09, 2011, 09:49:49 AM
:D
we would know that was a fib since bill built his own mill!   pc
pc
HuZzEy
when I got my thomas 2411 I put my 2nd new blade on and hit one of my backstops I backed the saw up and rammed it again before I noticed it wasen't gonna go newb mistake I slow down before I get to them now and watch
barbender
One problem with Wm hydraulic mills, when you get into a cut far enough to realize that your backstops are too high, you are no longer on the contact strip that powers your hydraulics, so you can't move the backstops without backing out of the cut. If you back up with the blade engaged, it jumps off the bandwheels, usually ruining the blade :-[ I've done this many times, I hope someday I'll learn. Sometimes I take a chance and try to go past the backstops,  hoping I'll miss
Usually I don't  ::) It's good for variety though. Bill, if I was you, I would complain to the manufacturer about not making some sort of gaurd  to keep you from sawing into your turner ;D
Mine did come like that.  Here is what the tip of my log turner looks like.  As you can see, half of the tip is sawed off, courtesy of the previous owner.
Since the blade was ruined, he said that he just wanted to see if it would finish the cut!
