Early JD 440
Started by JacksonBros, September 25, 2011, 08:17:46 PM
JacksonBros
Well im fairly new to this site but,
Just got my very first skidder, being a john deere mechanic for several years after college, I like this particular model 440 because of the easy to fix synchro-range trans thats used in many ag tractors. This was an extremely good find I feel with it having super tires, new set of chains to go with it is and a fully rigged winch line. I only cut part time and on the side so pushing it to the limit of over loading it wont be a problem. Just gonna have some safe fun on it. Here are some pics let me know stuff about it that I may not know! I love to hear different things and learn from others.
Decked
Looks like nice machine! blade isn't all bent up..somebody was good to her. I had a '69 540...dam near put me in the poorhouse.
JacksonBros
It took many dissapointed trips and long wasted hours looking at junk machines but persistance pays off I spose. As for the 540's I looked at a couple and wow was they worn out hard...
snowstorm
what year is it? gotta be 66...67...? its not an A still has the single lever shifter. jd made a kit to change them over to 2 lever..........back in the 70's
mad murdock
Welcome to the Forestry Forum JacksonBros.  Persistence does pay off, that is a nice looking piece of JD iron you got there 8) 8) The 440 is a great machine, small and agile, about as close as you get to leave no trace, unless you are using hayburners, or going small scalel a.k.a. logrite arch and 4 wheeler, (not as much fun as busting brush in a skidder, IMO).  Though the Garrett I have is about the same size, and equally as suited.  Myself coming from the upper Great Lakes region, until coming across the machine I have, hadn't heard of the Garrett name, though I was plenty familiar with Tree Farmer .  Funny how things come full circle sometimes.  You will have some good times with your 440.
treefarmer87
welcome to the forum, very nice JD 8)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
JacksonBros
Well I ran the serial number by a guy I used to work with at JD and it comes out as a 66'. As for Garrett I have never heard of that untill now, I will have to look into what that machine looks like, sounds interesting.
mad murdock
  Here are a couple quick ones for you of what the Garrett looks like.  They sold the Tree Farmer line to CanCar in late 1964, I think TF87's machine is a later 60's TreeFarmer C5 or some iteration of it.  Mine has 59hp ford diesel power, and a Germatic 8A winch.  Prolly a little smaller than the 440A, but not much.  I can easily drag 500-800 bd/ft hitches without straining the machine too much.  Garrett was not as well known all around like JD, but Dwight Garrett invented the articulated skidder in 1949, in Enumclaw, Wash.
He knew what he needed in the woods, and the rest is as the saying goes, "history".  BTW, I have always been a fan of the old 440's, they were the best IMO, for their size and what you could do with them, of JD's line.  Bigger machines can do more, but they make a bigger mess as well, IMO.
snowstorm
Quote from: JacksonBros on September 26, 2011, 04:03:11 PM
so its one of the first ones built. gas or diesel? if its diesel it should be the smaller motor188ci? the 219ci came out later
Bobus2003
Darn good lookin little 440.. I've got one and love it.
treefarmer87
i believe you are right about about my skidder
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
JacksonBros
It is the diesel non turbo. I couldnt 100% tell you the ci, the serial number off the tag of the block i couldnt get an answer as to if it was original block or if someone has updated it cause the friend at john deere said back in those days he thought the numbers on the tag didnt exactly mean what it was for example the 4045, 6068 exc have that included in the serial number but my serial number is meaningless it seems as far as that goes, any clues?
acco1840
Nice machine mate!! Looks about the same size as my IH S7b. What size tires??
snowstorm
Quote from: JacksonBros on September 26, 2011, 08:10:19 PM
should be a tag on the motor. seems like they were 59hp the A was 70hp
JacksonBros
Wondering if anyone knows but just was checking all the hubs tonight and noticed one that looks to have the epoxy repair that I am assuming was used because it had some play in it? Does anyone know about these style hubs and if I should be really concerned about this? All of the hubs are nice and tight on the axles but just noticed this and want to know what to look out for in the future. Thanks
snowstorm
Quote from: JacksonBros on September 27, 2011, 06:51:17 PM
i would be concerned if it didnt have expoxy. that was deeres fix back in the 70's. new hub set in plastic steel. didnt have any problems after that. could a new hub even be found if needed?
Bobus2003
All my Hubs have JB Weld on them
thumper
yup, if the weld is still there thats good. once the hub starts slopping it will soon strip the hub to axle..  usually a drill hole in the hub that was for filling the weld.
Jonsered 2150 2152 2156 2165  Husqvarna 262xps Worn 1970 JD440a 06 GMC 3500 DURAMAX
redprospector
That's a good lookin' little 440!
I've got a 1973 model 440b. It get's used every day in my thinning operation.
I know what you mean about many disapointing trips, and wasted time looking at junk. When I bought mine it was a basket case. I had my doubts when I was putting it together, but after I put her to work I've never regreted choosing the 440.
Andy
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
JacksonBros
Here is a pic in the middle of the painting process. I was taught by an older guy where I work how to paint old equip cheap but with professional results and it had worked amazing. You roll on the paint then directly "tip" the wet paint with a fine bristle paint brush and it blends into a solid gloss with no stroke marks or anything. Here she is only half done
mad murdock
wow!  nice technique there Jacksonbros!  that is looking migh T fine 8) 8)
Looking good. Is it JD yellow paint?
And not sure how you can "roll" on paint?  it implies using a roller.  ::)
If it works, great. !!
JacksonBros
Just installed new factory seat pads I got from a JD warehouse that has been over head in storage for years! As for the paint color it right from JD and its Classic Jd Forestry/Construction Yellow
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
sprucebunny
Great looking machine  8) I hope it works well for you.
I learned the same painting technique for putting fine finishes on boats. I haven't had very good luck doing it with Rustolem, though. Might need to add a flow agent.
JacksonBros
Haha Im a boat mechanic at a shipyard, the guy that taught me is a painter there, to funny
toploader Ford
Yep, good lookin old skidder. I had a 1970 model 440A, very low maintance machine and pretty easy too fix.  I learned, in the winter time, to take the front grill off and releave the pressure on the pump, before starting. Takes alot of strain of the starter motor.  Once warm it was ok.
Ken 45lc
Very nice looking machine.
I ran a 440A for a few days when I was in my early teens, it was the first real skidder I ever ran, before that was a farm tractor. I was amazed how much more the skidder could do, and how many more places I could go with it. I thought I was a professional logger the few days I got to run it. I was really disappointed when I had to go back to using a farm tractor after that.
Could you please explain your painting technique a little better? Your paint looks really good, and if it's easier i'd really like to know how you did it.
Taylortractornut
Thats a nice little skidder, theres one for sale  at the tigercat dealer  down the road from the house.    Theres one at work  near the landfill  been doing a good job hauling out logs.   THey have the topper   hooking the chokers and  another one    unhooking them  at the landing so the driver doenst have to get off the machine.
My overload permit starts after sunset
JacksonBros
Well here is the finished machine. Thanks to everyone for the good comments and info, hope everyone liked seeing the old skidder get a makeover.
- Ken45lc, as for the painting it was pretty simple, I used a normal fine finish paint roller like you would for painting walls, and then a fine bristle brush for the final go over. As for what i found worked best for me was to use the roll to get one coat on everything i could hit with it then with the brush get all I couldnt get with the roll as least once. Once it got tacky I rolled everything again and brush again exc. Lastly I used the brush to go over with a light coat to take out all air bubbles and imperfections. I did use 2 cans of spray in hard to reach areas. So total paint was one gallon and 2 spray cans. about 90 bucks. I dont think it was a bad investment for the paint.
She's a beauty, and parade ready!! 8)
brendonv
Looks great!
I was on a job Sat. morning where we used a JD 440 to pull a large back leaning Sugar Maple over.  That machine backs some power.  If I ever run across one for a decent buck I might pick one up for myself.
Nice job on the paint, I too was wondering the process as I'm about to paint an old cast iron bath tub.   :D
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Bobus2003
Looks really good.. Mine got repainted about 6 years ago.. she doesn't look so good anymore.. amazing how quick they get scratched up
redprospector
Wow! You may have just inspired me to go buy some paint.  :D
Andy
YupperYooper
Quote from: JacksonBros on October 09, 2011, 07:19:06 PM
NICE!!!
Stihl 025, 18" bar
Antique bucksaw
Single-bit axe
2-ton come-a-long
5akman
What brand paint did you use? One part or two part? Any primer needed?
1978 JD 440C
I enjoyed the makeover.  ;D
Ron Scott
~Ron
Norm
Corley5
That looks good  8) 8) 8) 8) 8)  Too bad to take it to the woods and scratch it all up  :)
CX3
Howdy I like your skidder.  I still have one just like it.  Thats what I started with.  There are 2 things you should know about this skidder.  First, dont let its size fool ya.  It can work 10 men to death in one day.  Second, you and the wife be prepared for you to quit your job and become a poor logger.  Once its in the blood, well you will find out the rest.  LOL.  Good luck buddy
John 3:16
You Better Believe It!
