Author Topic: Low impact logging equipment breakdown  (Read 3966 times)
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« on: September 22, 2011, 07:34:08 pm »
O.K., it.s my quad.  Unhooking a skid I noticed I must have snagged a stick or something and tore the heck out of the CV boot on the rear right inner axle.  Has anyone ever changed one of these?  Is it something I dare try to do up here at the cabin with limited tools?  I'm out of commission until I get this fixed.  I don't imaginme the boot is terribly expensive, but I'll bet having it replaced at the honda dealer is very expensive. How do those clamps work that hold it in place?
Offline 250quality
Re: Low impact logging equipment breakdown
« Reply #1 on: September 22, 2011, 07:54:05 pm »
Done mine on my Brute Force a couple times. Pain in the a## though but you can do it. Depending on the clamp style you may need a special tool. Need a tie rod splitter as well to get the a arm off.
Offline forestry mick
« Reply #2 on: September 22, 2011, 08:02:37 pm »
They are not hard to replace at all, limited tools may be a chalange but if you need to keep going, get to a local auto parts store they sell split boots that you can slide over and clamp in place in about 5 min with nothing more than a bar tool. stock clamps that honda uses from the factory use a special crimp tool but pop off easy (hook and loop looking setup). It is an easy fix but at the same time honda may want to sell you a whole new axle shaft, after market will save you and alot of money, any dealer will have a parts unlimited book listing all the parts you need! I am a local motocross racer and fix way to many peoples broken off road toys on the side so I have a vast knowlage of all things off road!
Mick
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« Reply #3 on: September 22, 2011, 08:10:21 pm »
Done the same thing on the rear of my Kaw. 650. Had to remove the A arm bolts on the wheel and shock. New one was about $20.00 and it came with lube. The new clamps were a little different than the orig. ones. They are a little tricky to put the clamps on. You might try wire ties for a temporary clamp untill you get it home. Some vehicles us them in there repair kits as a permanant fix. Good lucl, bg
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #4 on: September 22, 2011, 08:13:38 pm »
Mick, I'd assume you cut off the old boot before putting on the after market split boot?
« Reply #5 on: September 22, 2011, 08:40:26 pm »
Yes remove the old boot and clamps clean all dirt, Breakclean works the best, repack with grease and slide the split boot in place. I have seen some split boots last for years others for only days. one thing, take your old boot with you so you can match one up (can be a little bigger) and a pack of HD cable ties and you will be in good shape!
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #6 on: September 22, 2011, 09:32:54 pm »
To put on original equipment, do I have to have two new boots?  Does the outer boot have to come off to change the inner one?
« Reply #7 on: September 22, 2011, 10:04:01 pm »
you need to take the whole axle off, then you can change one boot at a time or just the one thats needs replacing. once out remove the old boot and then depending on degsin there eill be a retaining ring that must be removed then you can seperate the shaft, and the 3 cv balls, instaling the new boot will require some patience to get it on but in all isnt to tough
Offline thecfarm
« Reply #8 on: September 23, 2011, 06:32:49 am »
Like I say when something breaks,we're making money now. Working in the woods is hard on equipment,
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #9 on: September 23, 2011, 08:43:02 am »
Jeff,
I just replaced the front axle on my Honda Foreman. The inner joint broke. $179 for the complete shaft from a aftermarket online source. Doesn't look like you need the whole thing though.
Kubota L-4200, Ford 8N, S-10 4WD Beater truck, Chainsaw, Bush Hog, couple ATV's and 141 acres of trees I'm not sure what to do with but I sure do have fun and enjoy being in the woods!
The First 50 years of childhood is always the hardest.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #10 on: September 23, 2011, 01:30:39 pm »
I just dropped my bike off in the Soo at the honda dealer. Quote was for $100 parts and labor for putting the boot on. They said they could get it done this afternoon and I should be able to pick it up tomorrow.  :)   I have a coupkle other odds and ends for them to look at while it is there.
Offline Ron Scott
    • Ron Scotts Web
« Reply #11 on: September 23, 2011, 08:28:18 pm »
Sounds good! Logging takes a toll on equipment.
~Ron
Offline Ironwood
    • http://www.branchandburl.com
« Reply #12 on: September 23, 2011, 08:42:11 pm »
nothing like having it done right for a reasonable price. Good deal.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #13 on: September 23, 2011, 08:55:42 pm »
After my last experience a couple years ago with a Honda dealer, I was a bit leary going into this, but all I can say is good things about Leitz Sports Center in Sault St. Marie.   I called them this Morning and they said they were busy, but could get it before wednesday, but bring it in and they would try to fit it in, estimate, 100 bucks.   Well, I had my truck tool box mounted and I am here by myself, but after a bit of struggle, I got it off and out of the way to make room for the bike. I went around the shed to get my ramps and CRAP. I had a brain fart somewhere and had taken them home.  So, we had some planks in our lumber pile here, so I improvised and got the bike loaded.
I drove to the soo, and was there by 10:30 this morning. Its an hour drive from the cabin.  I talked to Tiffany, the very knowledgeable gal in parts and service and got the bike unloaded. We talked about what I was doing here at the cabin, and that the bike was important to keep me busy.  Before I left, she said the mechanic was going to fit it in today, and I should be able to get it tomorrow. So, I went to walmart, stocked up on paper plates, toilet paper and trail mix and headed back home to the cabin.   At about 4 oclock I looked at my phone and saw I had a missed call and voice mail at 2:30.  It was Tiffany.  My Bike was done and ready to pick up. They would be open until 6:30.  So, I hopped in the truck and headed back to the soo. Turns out the estimate was off.  The bill was for $80 some dollars    ;D     I say that was a deal. If I would have did it myself I'd of had $500 worth of aggravation.  :D
I thanked Tiffany for going out of the way to get it done for me so quick. I mentioned I should have had them change the oil and filter as it was due, but I had forgot, but might as well get the oil and filter.  She said, hey, we can still do that for you, I'll go tell the mechanic to do it before they load it for you.
So, here I am back at the cabin with my beloved Rincon, and ready to go at it again in the morning (IF it quits raining)  :)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: September 23, 2011, 08:58:38 pm »
That was outstanding customer service.  So was the price.  It is nice when those two come together!
Offline thecfarm
« Reply #15 on: September 23, 2011, 09:00:53 pm »
Good service,well worth the drive. Was a nice day here,real warm,wet in the morning,from rain the other day.Dried out and the sun came out for awhile. Rain coming in at midnight,but suppose to stop mid morning.
Offline Ron Scott
    • Ron Scotts Web
« Reply #16 on: September 23, 2011, 09:03:33 pm »
Great Service! I'm sure that you will give them further business.
~Ron
Offline mad murdock
« Reply #17 on: September 23, 2011, 09:10:32 pm »
Wow, that is a story with a happy ending!  I guess that was a good test of the old shoulder, unloading the box and loading the bike yourself etc.  Good job!! You will be hacking at that hackmatack in no time 8) 8)
'64 Garrett 15A, JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #18 on: September 23, 2011, 09:12:38 pm »
Yup, I'll trade bloody knuckles greasy everything and profanity floating around my head for 4 hours of driving any time.  :D
I sure will give them more business, and it is already planned. I forgot to add,  that after my fiaso with Hackers in Houghton Lake last year, where they had my bike for three weeks and said that they could never figure out the rattle in the bike and wanted to keep it another week for a company rep to look at.  That problem was definitively diagnosed for free today in the short time they had the bike. Tiffany said she knew what it was as soon as they started it, and the mechanic agreed that it is a worn cam chain tensioner. They said I should get it fixed, but no reason to stop to do it until I'm done with my work. It can wait for that.  Tiffany said to call them up and they will order it ahead of time so they can get it fixed the day i bring it in. about $60 part and an hour labor.   They get $70 an hour with a $20 minimum.  Very Happy with this.
Offline Norm
« Reply #19 on: September 24, 2011, 08:32:06 am »
Wow, wish we had a dealer like that in our area.
