lenox blades
Started by wlf89, September 09, 2011, 06:40:39 PM
wlf89
any one running lenox woodmaster c blades,12'x1-1/4 .o42 1.1t
i am having trouble with them breaking after 2 sharpings.
mill is set up as to the book. seems like the last two batches i have bought are junk.
i have 1 old blade left that i have had a long time before the last 2 batches, with at least 5 to 6 sharpings and cutting litepoles.
so im thinking it has somthing to do with the blades,not the mill.
what do yall think?
paul case
where are they breaking at? if it is at the weld it is a maker thing. talk to the folks who you buy them from. if it is in the gullet it could be a sharpening equipment malfunction. if you are using a sharpening service thye may need to know this. if you are the sharpener then you need to look at your sharpener and what it is doing to the gullet.   pc
pc
Banjo picker
Welcome to the froum, I see this is your first post... 8) 8) 8)  I have used that blade in 1 1/2" and had no trouble with it....Tim
wlf89
Quote from: paul case on September 09, 2011, 06:49:12 PM
well i am new to sharpening them my dad always done the sharpening but he recently passed away but this problem was happening before then when he was still sharpening them but only on the last 2 batches,but like i said i have a couple older ones that still havent broke so im thinking its just the blades. but anyway anyone have any pointers on sharpening them i am usuing a norwood sharpener
ladylake
 I've been using Simonds for 9 years now and did get 1 box of 10 where every one broke after the first sharpening, switched to 3/4 tooth spacing for a while and no more trouble with breaking blades.  After the saw shop got in a new batch of 7/8 went back to that with no troubles. I'd guess every manufactor will heve troubles once in a while... Steve
woodmills1
I got one free lennox C at a show
I was amazed how good it cut
broke it  1 sharpen
just my experience not a full blown test
