gearmatic winch wont release?
Started by huskyxp, August 18, 2011, 04:27:31 PM
huskyxp
skidder sat for few months now she wont release at all, is this problem in the master cylinder not compressing the spring?(prob a thread on this but figured it be just easy r  to ask)thanks
John Woodworth
Rust on the Brake Bands, hook line to a stump and with the control in release pull it out with machine, you may need to do it several times, just usage will generaly clear it up. You may also find that after the brake band loosens up the drum will continue to wind in, that'll be rust on the clutches, my clear up with use, worse case remove the side cover and remove the bands and clutches and clean the rust off with some fine grit sandpaper.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
