cutting plastic culvert pipe
Started by catskillpond, July 26, 2011, 09:40:30 AM
catskillpond
Has anyone cut culvert pipe on your mill we have to dut in half 24 inch about 30.
I thought put them on cut in about 2 foot then wedge the cut end and go any thoughts.
        Thanks Scott
Pond&Lake Specialist Norwood MX34 and a whole bunch of other Iron
york
How are ya going to dog it??Why,not just get some lines on it,and use your skill saw??
Albert
Not sure I understood what you were trying to say, but I've cut 16" PVC/plastic pipe lengthwise with an electric circular saw.  Snap a line and cut on the line.  Also have cut on table saw.  Might have to rig a clamp to secure to the bed of a bandmill, but should work.
redbeard
just a couple of straps and a helper to steady it as you remove straps and finish the cut. I needed some concrete shoots. I somtimes use it to catch sawdust but it is a trip hazard if I offbear on that side.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Chuck White
As long as it's not an every-day task, why not just anchor the culvert to the deck with a couple of C-clamps at each end!
Then run the band through at a medium-slow rate of speed!
rbarshaw
I'd go slow especially the fewer teeth per inch on the blade, the pvc is thin stock and if you go fast it may catch rather than cut.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
POSTON WIDEHEAD
Good thought Rebarshaw. Never thought of that. It could get messy at high speed.
gunman63
stringline and then a cordless sawz-all
jcbrotz
I did this, deck screw it to a 2 in or thicker board and clam the board then saw and remove screws.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Slabs
Quote from: Chuck White on July 26, 2011, 02:15:29 PM
Maybe even run a board through the pipe and clamp it down to help hold the pipe straight.
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
Jasperfield
I've cut lots of corrugated culvert longitudinally (long ways); both smooth wall and corrugated wall, with a hand held jig saw using a medium blade.
It's quick and EASY.
DKinWA
I use a chainsaw when cutting plastic pipe to length and it is quick, easy and fast.  I would do the same thing if I had a need to rip one in half and didn't need perfect looking edges.
ladylake
If only have a couple to do by hand, if a lot I'd use the bandsaw.   Steve
catskillpond
Thanks  Guys  We usally use a skillsaw but the more I thought about it only could cut a 8 inch slice and not a 12 inch like we wanted Norwood only has a 7 inch throat
Shake5150
Hud-Son offers a bandmill that is designed to cut pipe. Its used in the recycling business.
loggah
Chainsaw quick and easy, done in no time,thats what everyone i know does when building logging roads and putting culverts in.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
YellowHammer
I snap a chalk line and use a chainsaw. Cuts very easy and fast.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
drobertson
I agree with the chain saw as well, if it is a critical dimension then the clamps are a good idea. Keep the guides close and move on through. I have cut plastic, just move on through.  The only issue is tolerance.  If not a big deal chain saw and get er done.
Chuck White
Yup, chainsaw works really well splitting plastic culverts as well as cutting them to length.
Welcome to the Forestry Forum, Shake5150.
two-legged-sawmill
Hello, the mill that Hud-son sold this 60 inch mill to, produces culvert pipe and they claim to split miles of it. It evidently works as they are talking about an even bigger one!
"There are no secrets to success. It is the results of preperation, hard work, and learning from failures"
Bill Gaiche
Put the pipe on the bed of the mill. Slide a 2x6 all the way through and clamp both ends of 2x6 to the bunks. You may need to shim up under 2x6 to the bunk to get a good clamping surface. Cut slow at first to see how it reacts, then you can speed up if all is well. good luck, bg
Nomad
Quote from: Bill Gaiche on February 07, 2013, 10:35:11 AM
     That works well, but I found you need to brace the off side with blocking to keep the piece from shimmying side to side.  4x4 worked well for that.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
