picked up an old kuster drum sander (pictures)
Started by woodmills1, June 16, 2011, 09:02:16 PM
woodmills1
I know there is a thread or two with this as the subject
I bought a kuster 24 inch single drum today  5 HP baldor  only had to upgrade to a 30 amp dryer plug
THE THING sands like no tomorowwow
after I got the coreect cut line for the paper
woodmills1
no posts well thats fine
woodmills1
put this on woodworking no response
300 bucks  bought a kuster drum sander  OMG sands to no tomorrow :o
5 HP baldor and a box of 120 grit 4 inch paper to boot
did I say it sands lika planer ;D
ljmathias
Love to know more about it, especially with pictures, as I have no idea what you are talking about.  All I gather is that it is a heavy duty sander of some kind- drum may?  Help us ignorant ones out a little with more of a description.  I've used planers and hand sanders but never had the money or inclination to get a more productive sander, and probably need to...  ???
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
isawlogs
Cool , I always wanted a drum sander , all I have is my old trusted makita belt sander .
Get some pics  :)
   Marcel
JV
Can't say I've heard of them.  Looked at a picture on OWWM, looks like a heavy machine.  Double or single drum?  Regardless, at today's prices for even "economy" sanders, that's a good buy.  Sure beats hand sanding.
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
When I saw kuster, I thought cluster, and thought that you might have had some bad luck  :).  I am not familiar with it either.
http://vintagemachinery.org/mfgindex/detail.aspx?id=508
We once had a cabinet shop here that built church pews.  They had a huge drum sander that they ran an entire seat or back through.
Quote from: woodmills1 on June 18, 2011, 06:45:35 PM
Prolly not.
But we're waiting for the pics and some more presentation of the purchase. You skipped all that. ;)
woodmills1
pictures
the machine with dust head off
the drum wrapped with 120 grit after I figured how to do it
you can just make out the baldor nameplate here
terrifictimbersllc
Looks like you just wrap the drum from a narrow roll of sandpaper, then trim at the edges....how does it stick on?  Is that a common feature of other drum sanders?
ely
that looks like a good buy. those things are handy as a pocket. i dont own one yet.
sandhills
Please pardon my complete ignorance, I'm no woodworker by any standards, does a double drum sander sand both sides or does it use finer grit on the second drum?
pigman
Usually finer grit is put on the second drum. Some put the same grit on both drums  just to sand faster.
woodmills1
the edges are held with masking tape
the manual speaks of a slit to put the first side in but it is not there
the secret is the angle cut on the paper
I got that from vintage machinery
woodmills1
picked up a 70$ per hr job making finished boards from some old take off barn wood
the kuster sold the job
did 2 test pieces for the customer
plane, joint, rip, joint  they were happy
sanded on the kuster    they signed right up
Warbird
Thanks for the pictures.  That is a nice piece of equipment!
woodmills1
seems lika good fit to the Woodmills formula
Larry
Quote from: woodmills1 on June 28, 2011, 10:37:32 PM
Once you get the correct angle cut a pattern board.  Makes changing sandpaper much easier.  I have one of the Grizzly machines and it uses clips to hold the sandpaper...duct tape works well also. ;D
Another trick...Grizzly sells a hook & loop conversion kit for there 24" double drum sanders.  It's $29 and a great improvement.  Should be plenty of material to do your machine.  Downside is you have to buy H & L sandpaper.
woodmills1
I got a huge roll of 4" 120 grit in the $300 price
one pass from planer to 120 grit....priceless
having this place to post it
OMG how good, how nice, how well run
once again too busy in the summer to pig roast with u, but in spirit I am there
Sanding, sanding, sanding.  More sanding, then more sanding.  I need one of those new fangled drum sanders I guess.
What is the verdict on those that have them.  Are they worth it?
I don't have a drum sander here, just a stationary 6" belt sander with 12" side wheel by Sears and a 3" wide Makita belt sanding like Marcel. But a drum sander for doing panels and table tops would be a cat's meow because you have more control on depth and even sanding. ;D I use my Sears and Makita on most projects. ;D With the stationary belt sander I can "carve" some pieces and finish up on my inflatable flexi-shaft mounted cylindrical sander I hook to the lathe with a special arbour. That was a nice purchase last winter to. ;D
My cherry cabinet legs and hips from last winter was a combination of both. It's done in much the same manner as Dodgey carved his axe. Draw on centre reference lines on each face and they are the depth of the curves, just round the corners.
Don't complain if you have to pay a little more for good sandpaper. I have to get all mine from Lee Valley now, the locals just sell junk.
Norm
I have a Jet drum sander Danny and have been impressed with it. I'd rather have a wide belt but don't have the need or budget for one.
Maybe my plight is to just sand and sand.  In a way, it is relaxing if you get into a zone.  I am building a whack of walnut furniture (post to come soon in Woodworking), and I have had the occasion to sand for hours ( :)).  The time is spent in the finish sanding as that is key to a good finish.  I would hate to spend big $ on a wide drum sander and still have to spend a bunch of time finish sanding by hand.
