skidder tire size?
Started by rick f, June 16, 2011, 01:34:30 PM
rick f
Guys, my old clark has 16.9 x 30 tires now. My buddy found a pair of 18.4 x 30 skidder tires. How much diffrence is there in the rolling circumfrence of these sizes? Would it be a no-no to have diffrent sizes on the bak then the front?
Thank you
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
tyb525
I'm not sure how the 4x4 works on skidders, but on most vehicles with 4x4 the front and rear rolling circumference should be the same.
As long as they're all the same size, they should work.
overtime
ga jones
8 inches taller aint gona work.............
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
tyb525
It will if there arent fenders in the way
WH_Conley
Profile of the tire will make a lot of difference. The main thing is circumference, if that is the same they will work. It has to be exact.
Bill
acco1840
My old 1977 cat 518 runs 18.4 x 34 as standard. I ran 2 16.9 x 34's on the back and had no problem.
rick f
Thanks guys good advice as always
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
oldseabee
The Clark has no spins in both axles and no seperation  of the front and rear drivelines.  Odd  sizes will give you driveline wrap up and you will either be pushing two tires or dragging two tires, extra load on the machine and doesn't help tire wear either. Keep the sizes equal front to rear.
thumper
i think the width of the tires is the only diff. the height is close  with those two sizes..??
Jonsered 2150 2152 2156 2165  Husqvarna 262xps Worn 1970 JD440a 06 GMC 3500 DURAMAX
chevytaHOE5674
Quote from: thumper on June 21, 2011, 11:04:46 PM
A firestone 16.9-30 is 59.2" tall with a rolling circumference of 178"
An offbrand 18.4-30 is 60.9" tall with a rolling circumference of 196.5"
So one of the tires is going to have to travel/slip almost 20" more for every revolution. That is quite a bit.
tyb525
only thing I can think of would be to lower the air pressure in the taller tires, essentially reducing the rolling circumference. I'm not sure that would be a good idea, though.
lumberjack48
Do not run different size tires or you will be paying dearly in days to come.
rick f
Can you tell me were this info was found? I tried to find it and could not.
Thanks for all the replys.
I'll be putting on the 16.9 x 30. So they all will match.
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
chevytaHOE5674
I got it from the firestone ag website, and some other website that listed a 18.4-30 tire.
saltydog
there both 30 s i would run them. no different than having well worn rears and putting on new fronts. who can afford all new tires nowadays? mine are over 2000.00 each. ill be runnin used tires the rest of my life.
Proud to be a self employed logger.just me my Treefarmer forwader Ford f600 truck 2186 Jonsereds 385 and 390 husky and several 372s a couple 2171s one 2156  one stihl 066  Hudson bandmill Farquhar 56"cat powered mill.and five kids one wife.
thumper
Quote from: saltydog on June 23, 2011, 12:55:01 PM
exactly.. i looked at mine today, worn rears newer fronts. big diff in height.. id run them and make some money.  its not like we run skidders on hot top roads..
rick f
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
thumper
rick i tried to reply to your email but it wouldnt go thru..
