chains and cold shuts
Started by kelLOGg, June 08, 2011, 04:15:45 PM
kelLOGg
I have a couple of 5/16 and 3/8 chain lengths joined with cold shuts (welded shut) which I use for rolling logs onto a trailer and sawmill and related pulling and rolling operations. I probably never put more than 1000# (2500# tops beacuse that is winch max) of pulling force on them. I've never had one break in 20+ years. Now I need more cold shuts and when I google them I learn that they are only for temporary repair because they are mild steel. That surprises me - they close with great difficulty, requiring a hefty vise to squeeze one shut. That's mild steel!?:confused: I've also had good luck welding links together - never a failure. What's better a cold shut (welded) or directly welding links together? I'm reluctant to use the bona fide chain links because the cotter pins holding the links in can easily get damaged in dragging.
Bob
sealark37
I have never had much luck with cold shuts, welded or not.  Since I do not use my chains where a failure will cause damage, and I secure loads with redundant chains or straps, a cut and welded link has always sufficed.  The chains I have broken have been due to shock loads, when a slack chain was jerked taunt by a load.  I have broken links, bent hooks, and sprung binders, but I have never broken a link that I have welded.  I use 3/32"   E7014 rods.  Just my experience.  Regards, Clark
snowstorm
found a place that has cold shuts 3/16 to 5/8       try hamilton marine.com
shelbycharger400
i been around step dad pullin and dropin trees cince i was little.. from the farm and on.. .cold shuts just dont work and will let go when you least expect them.   cut the link and weld them,  or best yet is to put in a hook and pin, use a nail not cotter pin, and yes the old bent nail never fails  :D  just bend it in a z and clip it.  i know personally its a real pta climbing a 25 ft ladder movin in the wind tryin to haul up a 16 ft 3/8 log chain and wrap it round a tree  sometimes a short choker around 6 to 8 ft is real handy.
LeeB
http://www.gearench.com/products/x86-connecting-link.asp
Find one of these somewhere. You will likely never have to worry about it breaking on you.
indiaxman1
Had welded link break dragging white oak log last week...resorted to barge rope (actually leaving line) found on Ohio R bank years ago....realize this was not original purpose of this rope...but have drug/towed numerous logs (and vehicles) with it..have often wondered it other loggers have used similar method....it stretches and is somewhat frayed after all these years, but has never failed me
two tired
leeb we used them in the oilfeild a lot, worked great, can not ever rembering them breaking.
when wondering about weather conditions call the dog in and see if he is wet
LeeB
That's where I used them too. We don't use chains much any more, so haven't seen any for a good while.
Quote from: indiaxman1 on June 13, 2011, 03:40:49 PM
.....have often wondered it other loggers have used similar method....it stretches and is somewhat frayed after all these years, but has never failed me
Anything that stretches and then fails will be a flying missile, and not very safe in either direction. Hope that doesn't happen for you. ;)
kelLOGg
I decided to weld them. Overlapped 2 links leaving enough space for flexibility and put a continuous bead around the contact area. I plan using them in rolling logs onto a trailer.
Those Petol links look pretty cool but a bit pricey at $21 at Total Industrial Supply.
Thanks for the replies,
Bob
