Sycamore Flooring?
Started by Magicman, May 27, 2011, 08:10:43 AM
LOGDOG
I'm a big fan of those mixed floors myself. The contrast of the mixed woods actually seems to highlight the uniqueness of each individual species that much more.
scsmith42
The secret to minimizing degrade on sycamore is as follows:
1 - get a high quality end sealer on the ends of the logs the same day that they are felled.
2 - mill the logs ASAP after felling, quartersawing as much if not all of the wood.
3 - DO NOT AIR DRY!  Instead, get the boards into a low temperature kiln ASAP after milling.
When FF member Dad2nine and I have milled/dried QS Sycamore together, our degrade has been very low - probably less than 2%.
It helps if you do the felling and milling in the fall/winter/early spring too.
Tom's 3638D Baker band mill
Dodgy Loner
Quote from: scsmith42 on May 31, 2011, 09:45:44 AM
But it's early summer and the Magicwoman is cracking the whip!
I did a bit of looking   :o  There is one 24"+ Sycamore that I can fairly easily harvest.  It has vines and I can't see what length logs will be available.  The other available Sycamores are in the 15" range which will not yield much QS.
After I get the roof on the Cabin Addition, I'll concentrate on the flooring logs.
hackberry jake
I am thinking about doing the same thing Magic. Did you ever follow through on the sycamore flooring? And how did it turn out?
tule peak timber
Never tried it for flooring , but I've done quite a bit as T&G wall paneling. Rob
Quartersawn sycamore flooring would be a dramatic statement.  However, that would not be foreign to you, Sir, as you recently made a very dramatic statement on here.
PC-Urban-Sawyer
Quote from: WDH on April 11, 2015, 08:00:43 PM
Yes, but he did make a good point!
Herb
An excellent one, in my opinion  :D.
GeneWengert-WoodDoc
A little technical info.  The hardness of southern oka is 1060 pounds.  Sycamore, 770 pounds.  However, you might also ask "what hardness do I need?"  Maybe 770 pounds is hard enough for a floor...I think that at 770 pounds, it is hard enough to serve well.
Quote from: hackberry jake on April 11, 2015, 10:14:52 AM
Actually I did not follow through on the Sycamore flooring.  I used flat sawn SYP
1"X6" flat sawn non T&G SYP sub-flooring.
House wrap, and then various widths of T&G SYP.
Yes it is softer and easily dents, but it was available, quick, and this is "only" a Cabin.
Min-Wax Special Walnut stain and a coat of Poly.  (camera lens fogged up)
WmFritz
Lynn, that turned out very nice. How did you fasten the planking?
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
2½" 15 ga. finish nails randomly shot at an angle into the subflooring.  Not blind through the tongue as normal but surface nailed.
WmFritz
They're 'hidden' well enough to my eyes. I like it.
~Bill
In the beginning I had a pattern going, but I abandoned it when I realized that the pattern could be easily seen.  I could go back with a wood filler, but what the heck, it is "just a Cabin".
tule peak timber
Thanks for the comments.  When the sawing slacks off, I need to get back to my Cabin Addition that is waiting for me.  The flooring on that project will be flat sawn Ash.
tule peak timber
Make sure to use your Biobore or other timber treatment to fend off powderpost beetles . Ash for me is the number one bug magnate !
Thanks.  I used Timbor which is what I sprayed on all of the SYP lumber that I used on the Cabin Addition.   :)
tule peak timber
hackberry jake
I think hickory is my biggest bug magnet.
Mine is pecan, and pecan is a hickory, so mine must be hickory, too  ;D.
So it must be the Devil and his Wife?   ???
Deese
2004 LT40 Super 51hp w/6' bed extension
Cooks AE4P Edger
Cat Claw sharpener/Dual Tooth Setter
Kubota svl75-2 skidsteer w/grapple, forks, brushcutter
1977 Log Hog Knuckleboom loader/truck
hackberry jake
What flooring dimensions would be the most stable? Longer or shorter? Wide or narrow? I have made flooring once and we kept all the lengths 4' and shorter. This made machining much easier, but would it give the flooring too much leverage if it decided to move?
