6x6 boxed heart posts.
Started by weisyboy, May 11, 2011, 06:34:32 AM
weisyboy
got an order for 100 - 6x6 posts 6' long to fill.
started on it today.
30 down 70 to go.
didnt start the saw till 9.20 and finished at 3.
god bless america god save the queen god defend new zealand and thank christ for Australia
www.weisssawmilling.com.au
http://www.youtube.com/user/weisyboy?feature=mhee
http://www.facebook.com/profile.php?id=100000696669814&sk=photos
Kansas
Those side pieces cry out for a gang rip saw and then a resaw to get all the pallet boards out of them.
ely
i seen that picture of the slab pile and thought , man what alot of meat left on the bone.
:D
Piston
Quote from: ely on May 11, 2011, 08:40:07 AM
:D
That could make some neat siding for a small building, like an outhouse or toolshed or something.
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
sgschwend
WB, that a perfect part a swing mill.
I haven' tried this yet but I was considering using your split post idea to make beams.  Setting up so the wheels are on the left of my mill, which would allow for the setup of two log positions.  Left side log on wheels, right side log on mill frame and clamps.  Making the first two cuts there, using the wheels to rotate the log to 90 degrees, then set the 1/2 beam on the bed and make the last two side from there.  Should be a lot easier to make the big beams that way.
Steve Gschwend
sjgschwend@gmail.com
weisyboy
http://www.youtube.com/watch?v=Xi7e3oMbc-M
sgschwend- are you talking about cutting beams larger than the blade can cut
How about those shorts in the 4th picture.   :o
sgschwend
Yeah, WB, large beams or just making a cant for latter milling.
The largest I have made with the band saw was 6X24X25'.  The new frame will make ones up to 38'.   I did receive a call from a boat wright who wanted to have a mast cut but that was a 100 footer.  I heard later that when they were moving the mast and going around a street corner the mast wiped out all the stuff on the corner.
Steve Gschwend
weisyboy
delivered them yesterday.
5 ton all up bit heavy for the 'deo i suspect.
Coon
Is this the same load that gave you the extra workout?  ;)  Looks like it would be quite the rodeo on a rough road. :D
weisyboy
no it was the rails for the same fence that broke lose.
the old ute is legal to tow 2 ton, .75ton of tralier and 5ton of timber, sheel be right.
