Opinions on Makita DCS510
Started by big33, April 25, 2011, 10:45:28 PM
big33
Looking for a good firewood saw. Cut about 6 to 7 cord a year of standing dead or fallen trees on state land each year.  Trees range from 6" to maybe 20" in diameter with the norm about 14".  I'm thinking about the Makita DCS510.  Does it have a metal crank case?  How much of the saw is metal?
Welcome to the Forestry Forum.
What is the price of the Makita DCS510 with a 20" bar?
Do you have a dealer closer by or can you work on it yourself? I always push a good dealer when looking for a saw.
sawguy21
Almost identical to the Dolmar 510 which is a good mid range saw for farmers, ranchers, and weekend warriors.  ;D As thecfarm noted, dealer support is important regardless of brand.
John Mc
Quote from: beenthere on April 25, 2011, 11:33:19 PM
Bailey's sells them for $365.
Big33:
If I'm remembering correctly, the Makita saws are basically the same as the Dolmars with similar model numbers, just a different color. I know the Domlar PS-510 is a decent mid-range saw - not up to their PS-5100/5105 pro saw, but then the price isn't up in that range either. One knock I've heard against the DCS510 is that it's a bit heavier than a number of other 50cc saw options, but if that doesn't bother you, they are good saws for the money.
A good 50 cc will be a bit slow at the larger end of the size range you mentioned (especially if you are cutting hardwoods), but it will work -- just keep the chain sharp. I did exactly what you are doing with a 50cc Jonsered 2152 (twin sister saw to a Husky 353) for several years. Same HP as the DCS510, but weighs about 1# less. It was rare that I was cutting 20". Most of my cutting could be handled with a 16" bar, so that's what I kept on my saw.
I will second thecfarm's suggestion that picking a good dealer in your area is just as important as picking a good saw. If you can work on them yourself, maybe that's not as much of an issue for you.
John
SawTroll
Metal case yes - but is the heavier aluminum, and not the usual magnesium.
The saw really is too heavy for its power, but it is up to you if it matters.... :)
Why are there two of these threads?? ???
Information collector.
Greenerpastures
Old thread, no point in commenting.
