winchlines?
Started by treefarmer87, April 17, 2011, 04:49:29 PM
treefarmer87
im thinking about replacing my mainline on my winch. its only about 50-75' long now. the one on it now is a very thick line. im not sure what size to get ???
http://www.baileysonline.com/search.asp?SKW=winch line&catID=245
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Bobus2003
quietrangr
Don't get too thick of a line. They get stiff, and coil up more when they've been used for a while. I think the last one I bought was a 1/2 inch swaged.
tlandrum
i run 3/4 swedged to 5/8
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
treefarmer87
my line coils up like a snake now :( my buddy and i fixed the winch and it works like new :). im going to hook to a tree tomm. after im done, maybe it will get some kink out
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
snowstorm
best winch cable i ever had i bought from a marine supply store. yup same thing they use on boats
treefarmer87
that makes sense as long as its rated for heavy loads you are fine. cables are cables :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
bill m
Quote from: treefarmer87 on April 19, 2011, 08:15:35 PM
Well, not really. There are many different steels, left lay, right lay, anti rotational, swaged, cable laid, coated, high tensile, the list goes on. Many cables will not work for skidders. Make sure what you get has the correct construction/material for what you are doing.
treefarmer87
i didnt know that, i figured they were the same ??? what is the strongest?
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
nhlogga
Jonsered 2260
Husky 562xp
submarinesailor
Quote from: snowstorm on April 19, 2011, 07:48:17 PM
Snowstorm,
Can you give us some more info as to what cable and where you got it.
bruce
Ken
I think the required size is largely related to the type and volume of wood you will be hauling.  If you are going to consisently be pulling larger (20"+) trees go with a bigger cable.  If not why bother using something larger than necessary.  We only use 1/2" lines on our machines and can easily pull 1-1.5 cords per hitch.  I have worked around machines with bigger cables but I always thought they tended to kink much easier and were much harder (heavier) to haul through the brush.  The most important thing to keep in mind is to keep the line straight on the winch drum.  Eliminates the desire for the line to 'pigtail'.
Cheers
Ken
Bobus2003
Quote from: bill m on April 19, 2011, 08:33:05 PM
I ran a bunch of free cable a few years back that was from a 80 ton crane back in the day.. was nice cable but it would kink, and didn't handle rocks well at all.. Very easy to break if skidding through rocks
bill m
Quote from: treefarmer87 on April 19, 2011, 09:01:38 PM
The strongest may not be the best for this application. You need the right combination of strength, flexibility, and abrasion resistance. Not all cables will meet these needs. For example a 3/8 dia. 6 x 19 IWRC has a breaking strength of 15100 lbs., a 3/8 dia. 8 x 19 traction steel only has a breaking strength of 8200 lbs. and a 3/8 dia. 19 x 7 rotation resistant has a breaking strength of 12300 lbs. Go with what your logging equipment supplier sells if you are not sure what to get.
tlandrum
around here if your buying skidder cable i just about would bet its 3/4 swedged to 5/8. its the standard in these parts. it may be heavy but it will last a long time if you try to not side pull it against rocks and trees. what makes a cable coil up like a snake is the same principal as using a pair of scissors on a ribbon. .if you break the spin on the cable on direction it will coil up like a ribbon.
4233465399
What is involved in swedging a 3/4 cable to 5/8, and is the weight per foot the same?
snowstorm
Quote from: submarinesailor on April 20, 2011, 05:16:41 PM
Snowstorm,
bruce
hamilton marine searsport maine  it was 5/8 its been on there for a long time they even pressed the knob on it cut it any lenght ya want
bill m
6 x 26 IWRC 3/4 swaged to 5/8 is .957 lbs. per foot. 6 x 19 IWRC 3/4 is 1.04 lbs. per foot.
captain_crunch
Unless you constantly watch how line spools on winch no mater what it won't last We bought used 5/8 haulback off yarder lasted about 2 months per cat and with 2 cats working we put out about 5-6 loads per day. Look for used line if you can find it been stressed and streatched. Drum lines live a hard life no mater how hard you try to save them. What helped as much as anything was after fueling cat drain diesel from hose onto winch line lube helped it spool better
tlandrum
the reason i always use swedged cable is it has less friction when dragging the line out to your trees.  when gragging it it doesnt grab every thing it rubbs against like unswedged cable. i have a grapple skidder but when it gets to steep or too slick i have to go back to pulling cable. and i hate pulling cable. dragging 150ft of cable with 5 chokers is not exactly light. really a pain to drag up hill.........
4233465399
logger t
has anyone us that winch line rope
loggert
