Homemade bandsaw question
Started by Tyrin2saw, April 12, 2011, 01:57:46 PM
Tyrin2saw
Hi all how goes it.  I have been wanting to build my own saw for about a year now n have finally started. one of a bunch of questions i probly have is about the vertical guidance of the saw head. do people run bearings or just slip fitting peices of round or square tubing. will the slight jiggle between the 2 effect the cut.
thanks for any help JD
paul case
my ez boardwalk has square slip fit tubing with adjustable plastic rub blocks .
they have a metal strap on each side with a bolt and are on the inside of the head. you can see them in each picture. it only has one for each side. the plastic rub bars are probably 3/4''x 3/4'' and 2'' long.
pc
pc
JD,when I built my bandmill I used two legnths of 1" shaft one on each side with bushings in each end of a 12" piece of shelby tube attached to the saw head.Give serious thought to hydraulics to ease the strain of handling logs.Theirs alot of information in past posts may of us have built our own. Frank C.
The plastic rub blocks that pc described above are probably Teflon.  They should be available as replacements from most sawmill manufacturers.  WM also uses them.
tyb525
On my LT10, it has the semi-cantilever design. The "main" post is round, and there is a sleeve around it that acts as a clamp. On the other side of the mill is just a bracket with two plastic "bumpers".
fishpharmer
Hi JD,
Here is a link to a "simple sawmill"  website showing some details
http://kruppt.tripod.com/mill_2/img010.jpeg.html
My bandmill build began with the Bill Rake "simple sawmill" plans.  In the plans he suggests using a brass shim.  In my infinite wisdom (or lack of), I did not follow the plans very closely.  Some might say I didn't follow the plan at all.
Here is a pic of my bandmill showing the cutterhead uprights.
I simply used two different sizes of tubing, male and female (I think its the best way) with no shims or plastic.  I had intended to somehow shim the tubes to prevent any jiggle.  As it turns out, the sheer mass of the cutterhead prevents any play except when actually moving the head up or down.  When moving the head up, it wants to shift slightly to one side.  When lowering the head it shifts back and stays in that position.  I decided to adjust everything so that it cuts parallel to the log bunks when it is in the "shift down" mode since I intended to cut all my logs from the top down ;).
On the mill in that pic is a 36 inch diameter Southern Yellow Pine log.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Tyrin2saw
Thanks evry one for the replies and examples. Ive gone through tons of build posts old and new and 4 post seems 2 be more common. I  started buildin the main beam for the band wheels and due to lack of material i was headed toward 2 post. Im workin on gettin some pics up.
   JD
Tyrin2saw
I cant seem to get pics in a post  I got em into my gallery but thats as far as i can get.
    JD
You have the hardest part done. Once your gallery is open, and your posting window here is open, just click on your gallery pic and scroll down below it where there are two sets of instructions. Follow one or the other.
Let us know where you get hung up, as sometimes with computers one doesn't realize just how close to being successful we are. :)
Tyrin2saw
 Thanks beenthere was missin that part think i got it now.  1st pic is the driven wheel side
This is the adjustable side, blade tension, toe and camber
It is sitting upside down right now
   JD
You have some major mechanics going on there.   ;)
rbarshaw
It looks like you're usind tires for bandwheels, that's what I used on my first mill, works good. I'm not sure from your pics, but do you have enough clearance for your tires once they are mounted, looks like they might rub the cross member?
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Tyrin2saw
Quote from: rbarshaw on April 13, 2011, 06:16:28 PM
Yea im goin with tires on this one. i got a pair of shallow offset rims i run inside out with about 3/4'' - 1'' clearance to the beam.
I was wondering what width tires people r usin , i was thinkin maybe skinny donuts but dont no wats best. once i get right tires i'll measure for a band.
   JD
paul case
nice fab work there. looks like you are on the right track.  pc
pc
JD,your no pilgrim when it comes to welding and fabrication,I see you have your pussy in the shop for company. I would think those donut spare tires would be good.You may need a double "B" series pulley to drive the wheels.What are you planning to use for power.?? Frank C.
rbarshaw
Quote from: Tyrin2saw on April 13, 2011, 07:09:34 PM
   JD
I used mobilehome tires, i've seen probably every type of tire used, on this forum.
Tyrin2saw
thanks evryone for the replies.
Quote from: bandmiller2 on April 13, 2011, 08:25:39 PM
I only have a 5hp briggs sittin around now, but or big regional swap meet is this fri-sun. Theres got to be sumthin bigger that will work. maybe some 24'' donuts that would give me 32'' between wheels and 18'' depth from beam. allways good stuff to be had at the swap meet.
  JD
JD,don't be afrade of power thats something everyone here agrees on,the bigest engine you can handle on your bandhead. Electric is best if you have three phase.You don't know now how long your band will be,when you get the wheels you can run a tape around.You will have a range of adjustment ask the band supplier if theirs a standard legnth that will fit makes it much easier for everyone.They sell "V" castor wheels that run on inverted angle iron^     ^ with roller bearings that work well for carriage wheels.If your mill will be stationary and you have 110-220 v you can use that to run hydraulic pumps blowers est. to save engine power. Frank C.
Tyrin2saw
Went to the swap meet and scooped a tecumseh hh120 12hp for $50 w/ gas tank.  I think its late 60's early 70 w/ original mouse nests. It has electric start that i need ignition switch for but the internals are in great shape cylinder is perfect n it had compresion. Also got 2x 3/4''x36'' acme rods n nuts + 3/4'' bore sprockets for the lifting part. The head is getting pretty heavy wonderin if 3/4 rods will be enough.
JD,12 hp will do it but you still won't be awash with power.Are you planning to use screw thread and nuts to raise and lower the head?On my bandmill I used a hydraulic cylinder and wire cable to raise and lower the head controlled easily with a spool valve.If you have hydraulics its a simple matter to put a drum on a hyd. motor for cable feed.Frank C.
dovetails
Quote from: Tyrin2saw on April 17, 2011, 11:29:47 AM
Good deal! I have one looks just like it, took off an old rideing mower about 15 years ago,but mine is a 15hp,but the tank was bad. It has set on shelf in shop for 5-6 years,but hook gas to it, crank it over,and it fires right up.I used it on a big air compresor for a couple years,plenty of power on that. btw,I wouldn't let mine go for any less than about $200 if I was to sell it!  Easy to find bigger vertical shaft motors,side shaft not to common.  Love swap meets,go to a local one here every thursday and sat mornings.
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
buildthisfixthat
any progress on the saw build ?bearings appear a bit close together also do you have enough adjustment for  the wheels ?
shop built bandsaw mill
millwright
Great looking work. What are you planning to use for a clutch to engage the wheels?
shelbycharger400
3/4 acme is plenty for what your doing.   if you want you can look at my chain bar mill im building, i have done a lot cince last picture, mainly this last week i have made huge progress, but i cant find the camera :( , anyway on mine  between the 12.5 hp motor, the 15" x 24" x 1/2" plate, the clutch...its over 150 lbs.  and im just using standard 3/4 rod. 11 turns/inch.
I can tell you, for dollar amount spent,.. $20 to $50 on a used horizontal Kohler 4 in lawn mower electric clutch are nice.  they are around 150 to 300 new. .  i adapted one from a 12hp kohler, and its on a 12.5 briggs vert..  i bolted it to a 1/2 in thick plate.  mine isnt done. but its nice to know a flip of a switch, or im going to use a thumb push switch to activate the clutch.
tubing im using is 2inch, and 1.5,  all is 1/8th in wall.  their is about a 1/4 total slop,  but with 4 corners sliding, the weight between being lifted on 2,  3/4 rods.. its very little rock, if problems arise, im going to grind a hole on one of the angles and weld in a weld nut, and put a bolt in, and slight tension. but the support tubes are 12in long.  when i build a new one.. im goin all aluminum... industrial erector set... also known as 80/20  No welding required.. drill a few holes, buy the corner brackets, bolt together.
One rule of thumb, over do it,  plan on everything you can thats in your control, then it will be the best you can do.  i planed probably 6 months.. with looking at several, many many pictures of slabbers online, and mine has taken over 2 years to construct, and i already have a list of things to upgrade, and im still workin on it.   also note.. the feet is stabilized over 3 ft, all 4 corner wheels are adjustable ( for welding warpage issues) trailer is 14 ft long. toung to tail.  with capable of cutting just a 9 ft log,  but i have crossmembers 12in on center,  2 are solid,  6 are removable.   the 6 contain the dogs,  that the dogs are all adjustable for 4in up ,,,then down. as well as in and out. in short..  the carrage was capable of 29 in wide, 34 in high, 11.5 single pass.  now with wheels on, ect,  main rails of saw deck (trailer) are 3 in sq tubing,  my crossmembers are 28 1/4,   dog pockets are 2in sq tubing with a set screw,  the max dia i can clamp at 4 in up or down is about 24in wide.   this is why i went with removable crossmembers. so when i come across  some smaller stock (12 pcs at 4 in, in 3/4 stock, with something to pocket them in, then weld that to 2 in tube for sliding on 1 5/8 round )
