Woodmaster 3 side molding system
Started by rs1626, April 04, 2011, 08:09:43 AM
rs1626
Has any body used the 3 side molding system woodmaster sells for there machines?  trying to get some feedback as to how well it works or don't work  or if i would be better of with a logosol ph260
pineywoods
It's picky to get set up and the feed stock needs to be accurately sized. It does work quite well.
crowder888
I've got the 3 sided system on my machine and once you get it set up it runs some nice material.  Like pineywoods said you really need to pay attention to the set up (as with any machine) to make sure you get the best material in the end.  After that, it will run all day long
jdtuttle
If your looking to do production work get the ph260. I have a woodmaster & ph 260. I use the woodmaster to skip plane & then install the saw blades to make uniform sized blanks. Then I run the blanks through the ph 260 for molding. If your only making a small amount of molding the woodmaster is great.
jim
Have a great day
rs1626
 I  ended up buying a bridgewood cm-180  4 head  more $ than the woodmaster but less than any used ph-260 that i could find  I just picked it up  saturday we will see how it works out
woodhick
How have you been Rick?  Still have the LT40.  Are you getting into the trim business also or is machine for personal use?
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
rs1626
Hey Steve how are you doin  lt40 still going good moulder is for personal use now but who knows what it might bring glad to here from you
