Wood-mizer LT35 v/s timberking 1600
Started by red pine, March 16, 2011, 08:46:15 AM
ronwood
Steve,
How does your mill sense that your blade guide is hung on a knot and back of on the driving the head forward. It a good feature to have.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Tronvik
The only problem with woodmizer (IMHO) is they hold their value.  :D    If you ever need to sell,that orange paint sells itself. But I am not known to ever consider selling my 2. Some people keep spare parts, I keep a back up mill  :)
1984 lt30, john deere 750
ladylake
Quote from: ronwood on March 18, 2011, 12:34:10 AM
Steve,
Ron
It has a bypass valve .    Steve
terrifictimbersllc
Welcome to FF, Red Pine.  This is easier said than done, for me, but with $20K to spend, you might not be far at all from being able to purchase an older LT-40 super.  If you found an owner around who either isn't using his that much, or who is sawing a lot, but could be tempted to upgrade, you might be able to get a very good deal which would pay off in increased productivity and resale value.  Maybe more work than ordering a new one.  But not that much more work  in terms of upkeep, IMO.  These mills require eyes wide open with respect to maintenance and adjustments from one end to the other even if they're new, so the difference with an older one is that you might have to buy more parts, not that you have to know a lot more right up front.
ladylake
If your going to spend $20000 on a used mill you may as well spend $25000 on a TK2000 and get a real mill with 100% hydraulics except for the power guide. The TK2000 is built like a tank and should require very little maintaince.      Steve
red pine
r.man, thanks for looking into the Baker. By the way I would want a portable mill. Sorry I miss read your comments re: the Martin mill.   Red Pine
red pine
It appears sharpening bandmill blades is a big issue with need of sharpener and setter. Are there any suggestions for these tools as they appear quite costly from the manufacturers. I realize the cleanness of log is key factor and unfortunately water, power washers, etc. not readily available on my woodlot. Are debarkers worth gold in this instance. Red Pine
ronwood
red pine
I would recommend a debarker if you could afford it. Woodmizer has a resharp service. Some of the other manufacturer might have them.
Ron
r.man
Redpine the Baker is definitely a portable all hydraulic with a drag back. Will be able to check the model this weekend.
red oaks lumber
iv'e owned other brands..... go with w.m you won't be disapointed. you can talk about sawing wood or with orange you will be cutting wood. they have a first class customer service dept.
Bandmill Bandit
Quote from: red oaks lumber on March 18, 2011, 09:29:32 PM
My Grand dad always said Green in the field Green in the Bank. Yes they cost more to buy, command a higher price when you sell parts are bit more but you just have way less down time because ALL the parts are good as original so you break down less.
Wood mizer is the Green machine of the sawmills.
That Orange paint is worth every penny you pay for it and it will pay you back many times over.
In your situation Debarker is a must. I wouldnt buy a mill with out one now that I have it.
A couple of 5 gallon jugs of water a day will be all you need for the blade lube/coolant add a half cup of Tide or some other soap. winter time use windshield washer anti freeze with the soap as well.
When your out in a remote place cutting wood the last thing you need to be doing is running to town for parts every 3rd or 4th log. Sharpening gear is a good investment. Will pay you back in pretty short order WM build good sharpening system. I would spring for the dual tooth setter. I have the cnb grinder and love it. The single tooth setter is a PIA but it will get the job done.
ladylake
  Time to take the orange glasses off, WM is way to complicated. After 8000 hours on my B20 with very few repairs I made the right choise.  I get a  lot of comments from my customers that it saws better and faster the the WM guys they used to have saw for them. Cooks and Baker also have a nice simple mill.  Resale is a mute point unless you trade every year, I paid $20000 and would get at least $12000 for it now, not many of you will run a new mill for 8000 hours and lose any less than $8000 . Buying used a mill might not lose any value if you get it cheap enough.   Steve
ronwood
Steve,
What is your reasoning that the Woodmizer is more complicated that a TK.
Also a lot of how the mill cuts is how the sawyer takes care of the mill and how sharp the blades are. I  don't care what manufacture sawmill you have  a lot depends on the sawyer.
Ron
Chuck White
Red Pine
Welcome to the Forestry Forum!
I have always said "Anyone with simple basic mechanical skills and the ability to read can maintain a Wood-Mizer"!
This is getting stupid.  If you love your sawmill fine.  If you would recommend it fine. Talk about what you know and leave the rest of it alone, you don't need to be hammering on the other guy's choice on a mill if its not what you chose.  This ain't a pissing contest.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
red pine
r.man, Did you have chance to check on the used Baker and get the Model No. and perhaps hours used on the saw. New mills seem to have small discounts now, (Mar.31) but with metal prices up, they may cancel discounts. Thanks again.  Red pine
