small pines
Started by taylorsmissbeehaven, March 09, 2011, 02:00:33 PM
taylorsmissbeehaven
I have a customer who has 40 small pines they want milled. This was a young pine thicket and they are 12-16" at base  on the larger ones and tapper quickly. I tried to discourage them and suggested selling it for pulpwood might be a better idea but they really want this cut.  I told them I would do the best I could and get as much out of it as possible but some of it is just too small to be cut(3-4" on small end) does anyone have input on this job.  Thanks Brian
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
terrifictimbersllc
Little logs give little boards. Saw what they want at a price that makes you want to do it.
Approach it from the standpoint of advertising.  They are too small, but the more you get from them the more of a hero you become.   Just make comments along and along about how much you got from that "Stick".   You might also talk up the fact that he is being smart, wanting to use his own wood.  It makes the customer feel good.  But you also have to train them and show them, as you saw, why little wood is not economically advisable.  Nine inch tops are the starting point or the mill can't do a good job of clamping the log.  Make sure he is there for the sawing so that he can see what you have to go through.  :)
paul case
i have done some of that little log cutting on small post oaks from my property. framed my house with them. the slab management was a big deal. almost as much firewood slabs left over as there was logs to start with. for me it was crutial on those small ones to lift the little end and saw into the little end first. otherwise you spend a lot of time with a measure trying to figure out where to start and once in a while you ''miss'' and leave a board on the slab. go for it. i sawed a lot of little pines for a few customers and still got a good paycheck from it. pc
pc
DRB
I would charge by the hour not the board foot on little logs.  You can make money charging by the hour.  By the board foot you will lose.
woodmills1
note....... :D.....using a possible danger word
we call them pecker pines up here
Ifin they be straight they give nice but narrow lumber
red oaks lumber
by the hour
i had a guy bring in atrailer load of pine "logs" 4-7" dia. first thing i told him was "were not gettin 1x12's here" saewd most the day good for me not so good for him.
not matter thre size you'll always get sawdust and slabs
JSNH
While cuttin the small straight pine tops and getting only 2-2x4's out of one it seams to be a waste of time but those are the straighest and best framing 2x4 you make. I run a circle mill and it is pretty easy to zip thru those but there is no production to speak of.
tapper2
I use my circle mill and just bang through those small pines and spruce as fast as I can, real decent lumber. Saw small end first. Let the customer get what the customer wants. Whether they think it'll be cheaper than the local lumber yard, or they just want to use lumber from their land, show them the process, emphasize on quality of the boards, then charge them accordingly. Saw in 2x' and 1x's, to get the most for them. Small logs are great for sawing window jam extension, mop board, trim....etc.
Belsaw m14, 1992 Ford 1720, Homebuilt  bandmill, Franklin 120b & a bunch of worn out, banged up stuff........gotta love it.
Two slabs and a streak of sawdust. Tom brings up a good point we are in a service industry sometimes patiance and educating a customer is the best route.I cut some real doggy logs for a guy crooked rotten cores.I showed him the problems with his logs as I cut them,I'am sure I'll see him again hopefully with some better logs.
I didn't notice any mention of length.  There is considerable less loss from taper if they are bucked into 8' lengths rather than 12's or 16's.
taylorsmissbeehaven
Thanks for all the advice! I have them working on a cut sheet and we'll get together and let them see what i'm talking about. Magicman you're right. these logs are 18' long and cutting them down will help alot. Thanks again to all. Brian
