Our operation is underway!
Started by OlJarhead, March 07, 2011, 12:00:49 AM
Darrel
No, not dragging the mill, although I may come spring. I was visiting my sister who lives in Walla Walla.
1992 LT40HD
Kbeitz
Quote from: OlJarhead on February 02, 2016, 08:57:29 AM
Quote from: sandsawmill14 on February 01, 2016, 11:23:15 PM
what kind of cutters are you using?    great looking job  :)
I'm using Rockler T&G bits (I think MM suggested them 4 or 5 years back) and love them.  The bearings make using them a breeze with a portable router.
I just got my first Rockler T&G bits.
They are working great but I think they take more power to run than other brands I've used.
Love machine shop work
and Wood work shop work
And now a saw mill work
47sawdust
OlJarhead,
You deserve a present,buy that Lt35 hyd.It will make you happy and make you money.You have done a lot of great work.
best to you,
Mick
Mick
OlJarhead
Quote from: 47sawdust on February 02, 2016, 05:34:35 PM
OlJarhead,
best to you,
Mick
LOL now if I could get my wife to agree! :P
Then just buy it for her.  Seems simple to me.   ;)
OlJarhead
Chuck White
Been wondering what you were up to, hadn't heard anything from you in a long time!
Glad to hear you're still at it!   8)
samandothers
Glad to see ya back here posting on this thread.  I enjoyed it and glad to see it come back up.
OlJarhead
Thanks Guys,
I'll admit, I go through stretches of not posting much (and not milling much too! lol).  We're heading up in the truck tomorrow with all the new panel.  Will be an adventure!  I went up yesterday for lunch (that's what I call it) and barely made it up the first hill due to the solid ice!  Studs and 4x4 and still just barely crawled up the hill.  Made it the rest of the way pretty well and got the heat turned on and cranked up the wood stove.  Once things were warming (it was 22f inside) I headed back down the hill slippin' and a slidin' -- once again, thanks to the studs I was ok but I'll chain up next time!  Besides my big truck doesn't have studs and without chains it would be suicide.
samandothers
Need to get the LT35 to drag up there!  Might come in by spring!
OlJarhead
Got up to the cabin and almost finished off the loft paneling :)
Love the blue stain!
As for the LT35...my wife has tentatively agreed.  She wants me to put the mill back in action for customers on small jobs and if one of those "I've got 60 trees to mill" jobs comes along then she's ok with buying the mill.....but I've got to check lead times on the LT35 out west and if the above post is any indication I'd not want to have to wait too long!
Hilltop366
Hay your in luck, I got 60 trees to mill not far from you! ;)
OlJarhead
LOL
I have been looking at options and must admit I'm contemplating if the LT15 with powerfeed might be all I need for now since it's capable of more than double the production rates of my LT10.  The issue really is that the manual mill takes it's toll on me in a day of running hard and the hydraulic mills seem like a better option for this aging jarhead ;)
Basically I want to be able to compete with other portable millers though there aren't many around willing to drag their mills into the mountains in remote locations.  I've had to turn down several jobs over the last couple years because either they are too big for my mill (too many logs or logs that are over 24") and loading and rotating a 1200 pound log alone without the tractor is, well, darn near impossible.
My retirement plan is to be fully functional with a portable mill that I can produce a decent income off of.  So far my biggest job was just shy of 2000bf and I've had customers call with 2, 3 or even 10 times that much they wanted which I just wont try to tackle on my LT10.
No what I mean?
Hilltop366
To me the main reason the 15 is faster than the 10 is because it has a larger motor, which will give you less time to rest (while cutting) in between log and lumber handling of which you will be doing more of if the saw will cut faster.
More/easier log handling options along with faster cutting is going to be the key to increasing your output without running you off you feet.
OlJarhead
Quote from: Hilltop366 on February 08, 2016, 03:55:23 PM
Makes sense.  The 10hp upgrade on my mill nearly doubled the production on larger logs....wonder how hard it would be to upgrade to something like a 16hp motor?
Make sure that you get the 25 hp motor and the power feed.  Well worth the extra $.
Verticaltrx
There are several benefits the LT15 would give you that would really increase production:
-more power
-very good manual setworks (indexing wheel for height adjustment)
-power feed
The indexing wheel is something that a lot of folks overlook on these machines but I think it is an excellent system. It is a very fast and precise system especially if you saw a lot of 1" and 2" thick lumber. The power feed is also a huge labor saver and productivity booster. I was hesitant to buy it at first but now that I have it I can says it's worth its weight in gold, especially for a one man operation. I can easily do 250bf/hr by myself now that I have power feed, and be less tired at the end of the day.
Wood-Mizer LT15G19
gfadvm
Quote from: Verticaltrx on February 09, 2016, 09:08:41 AM
-more power
-power feed
That magnetic strip that was on my LT15 when I bought it used is handier than a pocket on a shirt (old saying). It is calibrated in 4,5,6,8/4 increments.
25 HP would be nice if my 15HP Kohler ever dies.
OlJarhead
-more power
-power feed
My biggest concern with manual mills is the loading and turning of large logs.  On my LT10 I can load with the tractor (at home) or the winch (in the field when no tractor present) but the winch can take 5-7 minutes to load a 1200# log and that's with help to keep it straight.
Then, once the log is in place it's VERY hard to roll even with my Logrite Cant Hook!  I've nearly blown out my shoulder a couple times rolling big logs on the deck.  These two factors are the reasons why I keep looking at hydraulic mills.
I'm a big guy too but I'm getting older (haven't figured out how to reverse that yet! lol) and though I once benched 350lbs I no longer can though I'm still pretty strong.  That's the rub eh?  The strength of youth leaves us and this old jarhead gets sore after rolling big logs around the mill ;)
I am thinking of hiring a helper while running the smaller mill though just to get the work going again until I can get jobs big enough to warrant a big mill.
pineywoods
You do have another option. Search "manual to hydraulic" Drawings, pics, the works..Originally for a manual lt40, but has been added to quite a few small manual mills. Most guys run the pump with an electric motor, others use an old lawn mower engine for power.
47sawdust
As long as you have all this well intentioned help I'll add another thought.A low hour Lt40 hydraulic would make a great upgrade.There are a lot of them around.Try a post 1997 mill as they have a heavier frame and the very popular 2 plane clamp.
Best of luck,maybe it's time for a donation post.
Mick
Kbeitz
I'm going to put hydraulics on my mill. But for now this little engine
lift is doing the job of rolling my logs and it's doing a good job of it.
OlJarhead
The bug has hit and the potential customers are starting to reach out to us.  Many with too many logs or too big for the small mill....so....we're now seriously looking at a new LT35HD.  If we purchase one we'll sell the LT10 and never look back! :)  Watch this space ;)
Seavee
Go for it. You'll keep it busy.To bad I think the lt35 was on sale last month.
Wood mizer lt50 47hp yanmar Diesel  Sthil MS311, Ms661 MS200T, 029 farm boss  and a New Holland T4  75hp.
OlJarhead
Would have been nice but maybe I can get them to give me the sale pricing ;)
Though, they seem awfully slow getting back to me.  I requested a quote over a week ago and no response.
