Question for you "Walnut cutin'Guys"
Started by Chuck White, March 03, 2011, 06:01:32 PM
Chuck White
I've got just a couple of Black Walnut trees to saw up for a customer in the Spring!
One of the trees is already cut down (2 months now), but not cut to log length and the other is still standing!
I've never sawn Walnut before, but I figure it would be a lot like Hickory or White Oak!
What would be the "ideal" blade to use to saw it on my LT40?  I'm thinking 1¼x.045x4° with lots of water going!
Ironwood
Dont really need alot of water, cut like cherry, only more beautiful ;D
Ironwood
red oaks lumber
sawwood
We cut lots of Walnut and use a 10deg blade. I like cutting Walnut as its easy pushing
the blade not like oak that is harder.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
nas
I cut lots of walnut, and it cuts much easier than W Oak or Hickory.  10° blades are fine.
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
terrifictimbersllc
Agree, walnut is easy to cut, 10's are good, anything really wide use a 9.  Nothing like hickory or white oak.  Tends to have a lot of stringy bark debris, if you use a lot of water makes a mess around the rollers.  Keep the guide arm roller cleaned off.  Crud can wedge the roller to the blade and yank the guide arm over.
Bibbyman
What they said plus it'll stain your hands like crazy.  When we sawed walnut day after day during the summer,  Mary would have a brown band around her ankles from the walnut dust soaking through her socks.
The sawdust causes problems for some people.  It will also kill out other plants.  So consider where you dispose of the sawdust – like, don't put it under your tomato plants in the garden.  Its bad for horse bedding also..  Something to do with foot fungus or something.
Sawing since '94
paul case
Quote from: Chuck White on March 03, 2011, 06:01:32 PM
it is softer than hickory or w oak and it is also lighter. oh yeah, the sawdust is black instead of white. pc
pc
Bibbyman
Oh yea,   and another fun thing about walnut,  it's not brown on the inside!  When you saw reasonably fresh cut walnut, watch when you pull a slab or a board.   It will be more of an avocado green in color.  But only for a few seconds.
Sawing since '94
5quarter
All of the above...plus it is relatively forgiving when drying. cut it straight, it usually stays that way. btw, thats alot of exclamation points...you're not yelling at us I hope! ;D
Blue Harbor Refinishing
carykong
I echo Bibbyman about walnut dust. Walnut sawdust is toxic.  If you do not have a remote operator station, wear a dust mask too.  Green walnut saws just as easy as pine. I sawed walnut logs that were three years on the ground with no rot.  The knots ,however, can be very hard on cured logs. Broke a blade on a walnut knot.
Chuck White
Well, thanks for all the comments guys!
I guess I'm all set then, I have almost 2 full boxes of 10° blades.
I just thought walnut was really hard, but I guess NOT!
Thanks again.
pnyberg
I'm not sure, but the walnut sawdust may be toxic to plants as well.  You might want to advise the customer to be careful how he disposes of the sawdust.
--Peter
No longer milling
5quarter
I Saw mostly hardwoods and random widths and always edge as I go. I QC each board for wane, bark and defects and sort them on the log deck. Then I go back through them and edge everything to largest dimension I can (the exception being nice wide stock that begins to run out after 4 or 5'). I too hate edging, but a clean stack of lumber is a beautiful thing and well worth some extra time.
Chet
5quarter
desregard above...posted in the wrong thread.  sorry.
Chuck White
Quote from: pnyberg on March 04, 2011, 04:25:06 PM
--Peter
Good idea Peter.  I will make sure he's aware of the potential problems with the sawdust!
Thanks for your response!
Chuck
tyb525
Green walnut saws fine - standing dead is another story. It seems like blades last half as long on an old dry walnut log.
I've noticed a lot of tension in green walnut, compared to other woods.
Bibbyman
The soft and deep walnut bark pick up every little rock and grit.  For some reason, people like to nail stuff to walnut more than any other tree.
Sawing since '94
tyb525
Any idea what causes color variation in walnut? Once dry, some are purple brown, red brown, or gray-purple. Is it soil, location, or a combination of everything?
