feller?
Started by treefarmer87, February 06, 2011, 11:01:54 PM
treefarmer87
thinking about getting a feller buncher, i am looking at 3 right now. One is a bell with he bar dangle head. The other two are a franklin 150 and 170 with 18" and 20" shear heads. any thoughts or helpful hints?
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
I would have a conversation with your markets about the shears. The markets up here don't want sheared wood. Too much fibre damage in the logs, drove them out of the woods. Hotsaws or bar saws might be a better move.
snowstorm
forget the shear no one will buy your logs. i had one i know what they will do. with out a grapple skidder your not gaining much
oldseabee
I agree that the shear is a bad bet unless you are only doing pulpwood or firewood, then if you get a chance to do some logs you are screwed. Is the Bell a super T, UltraT, or UltraC? I worked for Bell for a while and have some tech info in case you go that way.
As snowstorm said, a grapple is what is used or a forwarder. Your not gaining much ground if you continue with a cable skidder with a buncher or processor. Ever try to hook chokers in a pile of bunched logs?
treefarmer87
i bet its not easy hooking those chokers, oldseabee, it is a ultra T, i might get a 240 timberjack grapple skidder a friend has for $7500 before i get a feller..... the man that has the TJ has the bell also, he wants $6500 for the ultra T, new pump and bar/chain in the head. The next job i got coming up is a clearcut, it has a lot of smaller stuff, a cutter would come in handy :)
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
jeremiahdixon
An Ultra T for 6500 should be a heck of a deal unless its ragged out. I have a super T that I wouldnt sell for double that. A bell can help in alot of ways even with your cable skidder. It can place the cut end of the trees on a stump so getting chokers underneath the tree is never a problem. A Bell will run alot cheaper as well the most any 4 wheel bunchers. I recommend getting a 3/4 inch bar and chain to replace the 404 pitch if it hasnt been changed already. My conversion kit was little of 500 dollars a year ago and have used 5 chains that im still using today. I cut large oak timber on a regular basis and only regret I have is not getting it sooner. Tire chains are a must as well, even on flat ground Ive found. If the timber is in fact smaller you might be able to save time by choking 2 smaller trees with one choker. Either way good luck ;)
treefarmer87
its already been converted :) alot of people dont like a bell.. i do i think they are really handy. thanks jeremiahdixon
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
jeremiahdixon
Sounds like a really good deal to me. If its actually an Ultra. Should have joy sticks if so. If its not an Ultra will be Super....still really good machines. One thing to look for in Supers are 2 or 4 bolt turn motors on the wheels. Take one of the two plates off the very front of the machine, between the head and directly below your grill. In my honest opinion 4 bolt is alot better. Will be easy to look in there and tell. I really like my bell. People that tend to not like them are in fear of turning them over. I got over that real fast, the hard way. Before I ever even cut a tree with it while unloading it the first day I got it  ;D I have a few times since then as well but is no big deal. Remember that seatbelt and dont let flat ground fool ya...trust me.
treefarmer87
yep ill deff wear my seatbelt. ill just be careful with it.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
graves logging
860 tigercat with hotsaw. 8)i
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Meadows Miller
Gday
the BEll would be a good option and I have always liked them cheap,simple to work on and lite which makes them cheap and easy to shift from site to site  ;) there where alot of blokes down here and in NZ that use them with the Bell static delimber to drop, limb, top off and set into skids but I like the look of the stripper delimber's www.stripperdelimber.com i also like the fact that they do not have a motor or hydraulics to worry about either  ;) ask your mate if he will do a package deal on both the Jack n the Bell you never know Mate  ;)
Regards Chris
4TH Generation Timbergetter
treefarmer87
me 2 Meadows Miller. i really like the stripper delimber. i would really like to have one. im sure he will sell them as a package deal. that bell delimber is cool too, never seen one around here though :(
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
Meadows Miller
Gday
One of my mates has a bell delimber down here but he only uses it on small pulp logs on large jobs and motor manuals everything else but it has done alot of work for him over the years though mate  ;) you  also just carry a remote in the bell logger to open and close the limbing knifes and activate it  ;)
heres a clip for you too I found Mate  ;)   http://youtube.com/watch?v=l1k0M70juHk&feature=related
Regards Chris
Buck
That dangle head Bell is sweet. A lot of the guys that have them around here have newer and bigger machines but keep those for backups. They dont wanna part with em. Better make the pair deal and get that grapple.
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Meadows Miller
Your rite there Buck alot of them keep em in the shed here also theres one mill north of me I know has imported afew 225 loggers in from both NZ and Africa in the last few years they reckon its just to hard to find em here along with the fact that they want a min of 30 to 45k for an older logger you can land a fully rebuilt one for that price that looks n runs like a Brand New one from Africa you just have to know the rite people  ;)
treefarmer87
that bell is awsome. i saw a pic on google one time of that delimber being used on eucalyptus pulp.
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
arojay
I saw a Bell on tracks, on the internet somewhere.  Has anyone else seen one?
440B skidder, JD350 dozer, Husqvarnas from 335 to 394. All spruced up
oldseabee
treefarmer87
they are awsome on tracks, there is one in WV for sale with a swing boom on it. i saw one on machinery trader for $60000 on tracks. i wonder if they come like that or it is a customized project?
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
mjeselskis
Quote from: oldseabee on February 12, 2011, 01:41:47 PM
Check it out
Bell Tracked Feller Buncher
That this is pretty cool. I'd like to have one. Corny music though.
2006 WM LT28  1993 John Deere 5300
Husqvarna 562XP & 365 X-Torq
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
oldseabee
I never listen to the music!!!!!!!!! Bell did sell the tracked version for several years, they did a good job.
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
